Running topo out in the field prestently, found how to create a surface from collected points. Is there a way to make it dynamic so it will update as we shoot more data?
Are you looking for TIN or Contours on the fly?
Contour on the fly, basicly just a field check for coverage and rod heights. Got a newb on the rod in heavy cover and thought that might be an easy way to keep an eye on things from the instrument.
Suggest contacting MyTopcon.com as Pat said, they keep slapping my hand when I try helping on this forum.
Ok thanks
leegreen, post: 429735, member: 2332 wrote: Suggest contacting MyTopcon.com as Pat said, they keep slapping my hand when I try helping on this forum.
Really? I would have thought they would be applauding.
It is support like yours and Carlson's and the Javad evangalists that really encourages the uptake of new software.
I do think that the product managers at one or two of the larger manufacturers have their heads firmly up where the sun never shines...
jim.cox, post: 429778, member: 93 wrote: I do think that the product managers at one or two of the larger manufacturers have their heads firmly up where the sun never shines...
That's what prompt's the indirect calls. For some reason Topcon thinks I'm against them, in reality quite the opposite, I own lot's of their gear and support Topcon. Hard to understand their train of thought at times.
leegreen, post: 429735, member: 2332 wrote: they keep slapping my hand when I try helping on this forum.
That is unfortunate. Keep on truckin'.
