Inkjet/Laser/Multi-purpose paper and source.
8 Users
carl-b-correll
(@carl-b-correll)
I have one of the Brother MFC-6490cw units (copies [ok], prints from PDF [great], scans [good]) that says that it is an Inkjet printer. I pretty much love it, but there are things that I wish were better about it. Like, why won't it scan ledger size docs?
Anyway... can/should I use Laser printer paper in this unit? What's the difference? What's the ramifications? Can I use something more generic? The reason that I ask is that Inkjet paper seems to be much less readily available than the others. I like at least a 96 brightness/24lb bond. Anybody got a good hook up on legal and ledger size paper?
Thanks in advance!!
Carl
Posted : July 24, 2013 7:48 am
Bryan Newsome
(@bryan-newsome)
Carl,
I have the same unit. Mine scans ledger size. I installed the "Control Center 3" app from the Brother factory disk and perform my scans that way. You can configure the app to scan to different file formats, i.e. txt, pdf, etc.
As far as paper types, inkjet paper is more absorbent, laser jet paper has coatings to protect it from curling due to the heat of the laser printer, among other things.
I typically use 20# paper for everything except formal proposals. You can really feel a difference in the weight and flexibility.
Brightness makes a big difference. I use 94-96, whatever is on sale unless, again, a formal proposal, then I use the brightest I can find. In other words, I have a couple of different "stock" paper packs in my office which I can vary as needed. I burn through the 20#/94 brightness the most.
I have corporate accounts to the standard "office supply" stores. They e-mail me discount deals almost everyday, really...almost every day. They include discounts on paper purchases, by the ream, and can even deliver.
Posted : July 24, 2013 8:08 am
Target Locked
(@target-locked)
Carl, I have the Brother MFC-J6510DW. I can scan ledger size, but I had to monkey around with the settings in the "Control Center 4" software in order to do so.
Here's what I found: Open Control Center and pick the "Configuration" button in the upper right. Then pick "Button Settings", "Scan", and "File". Change the Document Size to Ledger and click ok.
At first, I tried changing the scan paper size in other setting menus, but they wouldn't "stick", it always defaulted to letter. Using the Button settings was the only one that worked.
Hope if works for you, too.
Posted : July 24, 2013 8:11 am
NYLS
 NYLS
(@nyls)
I was recently told not to buy the cheaper paper for use in an inkjet printer. Even though it costs less, it also causes you to use more ink. In the long run you will save money on ink cartridges by using the paper specifically designed for ink jet printers and save overall.
Posted : July 24, 2013 8:39 am
Bryan Newsome
(@bryan-newsome)
What Target said...
Carl,
I failed to detail the scan settings, but it is the same in CC3.
You can right click on the preset buttons, top pick starts "ControlCenter configuration" and set your preferences that way and they should stick.
Posted : July 24, 2013 8:51 am
carl-b-correll
(@carl-b-correll)
> Carl,
I simply cannot get it to scan ledger. I've toggled everything, reset the unit, rebooted the PC driving it. Nothing. Blah.
I just use the heavier paper for everything, but plats especially. I hate having to switch paper in and out of the bins.
Posted : July 24, 2013 9:30 am
carl-b-correll
(@carl-b-correll)
I just can't get it to scan ledger docs. It simply won't do it.
Posted : July 24, 2013 9:31 am
Sure you will get the cleanest and clearest print using the correct paper, BUT unless you change the paper type someplace in the settings, the printer DOES NOT know what is in the supply tray, so I don't see using more or less ink by simply changing the paper available in the tray, the ink head just sprays a certain amount of ink based on the quality settings and what YOU tell it the paper type will be. Sure it may not look as good, BUT for in house copies, it will probably work OK and the paper cost will be less and the ink usage should be the same.
In a former life I took a course of study in Office Machine Technology at the local community college that resulted in an AS degree, I then serviced Canon copiers for two years. A lot of copy quality issues are due to the quality of toners/ink and paper, along with humidity and how you store the products.
SHG
Posted : July 24, 2013 12:10 pm
carl-b-correll
(@carl-b-correll)
THANK YOU BRYAN NEWSOME!!!
I haven't quite got my paper purchasing figured out yet, but I got my ledger size scanning situation on my Brother figured out thanks to Bryan Newsome. Nice little talk too. Thanks again
Carl
Posted : July 24, 2013 12:52 pm
Great printer, I've had one for several years
I use Laser Print 24lb paper from Quill. Beware their packaging is terrible so don't order too much at at time. The box usually explodes before it gets to me.
Look thru the scan menu and there is a selection for paper size and quality of scan similar to the copy menu.
0.02
Posted : July 24, 2013 4:49 pm
charles-l-dowdell
(@charles-l-dowdell)
HP Multipurpose is a good quality paper that seems to be good for printing with an Inkjet Printer.
Posted : July 24, 2013 5:07 pm
Bryan Newsome
(@bryan-newsome)
You are more than welcome, sir.
'Sorry I got a little long winded. I tend to talk a bit.
Posted : July 24, 2013 5:46 pm
SIR VEYSALOT
(@sir-veysalot)
I bought refillable cartridges about 2 years ago and ink. Havn't bought ink carts since.
Posted : July 24, 2013 7:50 pm
