Eagle Point (2005) Failure in 2018
2 Users
flatpan2
(@flatpan2)
We are way behind the software curve but was something we know and works for our applications.?ÿ It appears that our network server which is running Windows 7 updated and apparently we lost the connection to our Eagle Point License on the server.?ÿ The following is the explanation from our computer consultant:
Itƒ??s hard to ever walk away from a problem without resolution, but in this case we should not spend more time until we get something from the vendor. ?ÿSo, to the vendor here is the breakdown:?ÿ
  • License server I running
  • Licenses are not being present
  • License server is using the attached license file
  • XP client endpoints can talk to the server, but the server does not respond with a license
  • In License manager app, no products are shown to be licensed
  • You will need a good license file
  • Current license files show being from 2010
  • License file is attached
If anyone out there is still trying to get by with 2005 Eagle Point and has seen this issue or has a solution, please advise.
Thank you
Posted : May 1, 2018 3:09 pm
mkennedy
(@mkennedy)
Did you see these posts on the Eagle Point support blog: http://epsupportblog.blogspot.com/
Posted : May 4, 2018 2:46 pm
