Converting .XLSX to .XML Feature code list
mark-flora
(@mark-flora)
We have a client that recently updated their code list and I need to convert it from a .XLSX to a .XML for use on our Topcon FC2500 data collectors using Topsurv as the field software. I haven't been able to find a way to do this, and my Topcon rep wasn't able to convert either. I was wondering if anyone had figured out a way to make this happen or not?
Posted : February 7, 2017 7:53 am
ladd-nelson
(@ladd-nelson)
Mark Flora, post: 412836, member: 12401 wrote: We have a client that recently updated their code list and I need to convert it from a .XLSX to a .XML for use on our Topcon FC2500 data collectors using Topsurv as the field software. I haven't been able to find a way to do this, and my Topcon rep wasn't able to convert either. I was wondering if anyone had figured out a way to make this happen or not?
I might be able to help but it would take something like Carlson Survey to perform the process. If you'd care to send me your .XLSX file, I'll take a look and will see what I can do.
lnelsonATcarlsonswDOTcom
Posted : February 7, 2017 9:11 am
leegreen
(@leegreen)
I have done similar., But using current versios. May be able to do this in Magnet Field or Office. I would safe the Excel file to a CSV., Then import. It should be backwards compatible.
You may also try TopconLink.
Not sure how well Carson suggestions above will work. TopSurv may be too old.
Posted : February 7, 2017 9:15 am
mark-flora
(@mark-flora)
I was unable to make it happen converting from .CSV and then importing. Also tried TopconLink, but it was unable to recognize the .XLSX format I need to convert from.
I checked on Carlson and couldn't find where to do any type of conversion.
I'm not even sure if I'm able to do a Feature code list with an attribute table on my current setup?
Posted : February 7, 2017 12:12 pm
