Civil 3D 2016 Survey Mapping Annotation Styles
(@pls-wi-ca)
Does anyone have a C3D 2016 drawing (or compatible earlier versions that would work with 2016) they could share that has standard survey annotation label styles set? With the style driven format that C3D uses, I am looking to have styles similar to the ones I had in the past in LDD/SoftDesk ( removed link Bearing & Distance above the line, Bearing above/distance below, Distance only below, crows feet, Radius & Length above/ Delta below, removed link removed link ).?ÿ
I don't know if I am missing something in the software, but these don't seem to be part of the preloaded removed link I know it's because surveyors have been removed (and the commands helpful to them) with the evolution of this software "upgrades" through the years, that seemed to be downgrades if you are a removed link
Posted : 28/11/2017 4:06 pm
(@stlsurveyor)
All of those desired items are automatic when you label the line using annotative labeling. You can edit the line label style you want, crowsfoot, etc.
Posted : 28/11/2017 5:32 pm
(@ctbailey)
Yes, the stock template ships with these, you just need to dig to find the label styles that you want to use when labeling the linework.
I'm attaching a Screenshot that lists the steps to find the labels.
Posted : 28/11/2017 8:21 pm
(@ctbailey)
Maybe the "attach" tool isn't working, or I don't know how to work it. I tried in Firefox and Chrome.
Posted : 28/11/2017 8:26 pm
(@peter-lothian)
If you search the MassDOT website, there is a template Civil 3D file with many of the label styles set up for surveyors use when submitting plans to the DOT. You can use the pre-defined styles as a starting point to defining your own styles, if you wish. Your state DOT may have something similar.
Posted : 30/11/2017 5:29 am
