Not sure if CS does this... but is there a command to create a sphere from a series of 3-d points on the sphere?
A 3-d version of circle by 3 points.
running CS2016
lanceboyle93101, post: 341368, member: 2061 wrote: Not sure if CS does this... but is there a command to create a sphere from a series of 3-d points on the sphere?
running CS2016
Can it do matrix math? Any 4 non planar points may define a sphere. It's just math (not simple math, but math none the less, lol).
running CS2016
I'm not aware of any such command. http://knowledge.autodesk.com/support/autocad/getting-started/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-Core/files/GUID-90AF19E7-6AA4-4D34-B435-1094210BA74C-htm.html&apos ;">AutoCAD appears to have a 3P (Three Points) option in its SPHERE routine but "the three points also define the plane of the circumference."
