carlson stand alone working with lats and longs
Dane Ince
(@dane-ince)
is there a way to label lats and longs in Carson? i am unable to see how to set up the project so that I could use geographic coordinates....
advice welcomed
Posted : August 24, 2012 4:09 pm
RoadBurner
(@roadburner)
My menu has Annotate > Label Lat/Long. Using Carlson Survey 2012..
Posted : August 24, 2012 4:28 pm
Dane Ince
(@dane-ince)
carlson standalone 2008 will check tere however thanks
Posted : August 24, 2012 4:29 pm
jimmy-cleveland
(@jimmy-cleveland)
Dane,
2008 has the same menu option as listed above.
Jimmy
Posted : August 24, 2012 4:44 pm
Dane Ince
(@dane-ince)
Yes but what about importing lats and lons or assinging points by lat/lon?
Posted : August 25, 2012 10:31 am
Georges
(@georges)
Have you set-up your coordinates system in the drawing settings?
Posted : August 25, 2012 12:03 pm
cptdent
(@cptdent)
Set your coordinate system to UTM and knock yourself out.
Posted : August 25, 2012 12:43 pm
RoadBurner
(@roadburner)
I don't think it will do that. I use Corpscon to convert to state plane.
Posted : August 27, 2012 8:35 am
Kris Morgan
(@kris-morgan)
In the drawing set up, define the datum you're working in. Then lablat and it will set the lat and long at the corner. This worked in 08 and 12 also.
Posted : August 27, 2012 8:38 am
