Carlson Plotting Question
(@jon-payne)
Carlson 2013 w/ Intellicad 7
I have previously added some fonts to use because I prefer the Courier font.
I have used this font for over a year and plotted many drawings with no issues. I currently have one drawing that is giving me a hard time.
I've already double checked that I have the fonts directory looking in the right place and that the courier font is in that directory.
Here is what is happening:
Font as it appears on screen -
When I plot (either to PDF or on paper) it looks like this -
What setting have I messed up? Since it was working fine for so long, I expect that it is something I did.
Posted : August 7, 2014 12:44 pm
(@ladd-nelson)
The only thing I can think of is some type of scale has been applied to the Courier font. From http://support.microsoft.com/kb/918791 :
>Raster fonts are also named bitmapped fonts. They are stored as bitmaps. A bitmap is a pattern of dots. Raster fonts are designed with a specific size and with a specific resolution for a specific printer. You cannot scale or rotate raster fonts. If a printer does not support raster fonts, it will not print them. The following fonts are the five raster fonts:
  • Courier
  • MS Sans Serif
  • MS Serif
  • Small
  • Symbol
You might experiment with the "Courier New" font.
Posted : August 8, 2014 6:40 am
(@jon-payne)
Ladd,
Do you ever feel as if it is a burden to know all things Carlson and even slightly Carlson related?
I just logged on and saw your reply. Swapped all of the Courier to Courier New and it works perfectly.
Thanks for the solution.
Jon
Posted : August 9, 2014 6:45 am
Guest
I've seen that sort of effect in IntelliCad and Microsurvey.
Curious as your Carlson is IntelliCad it is in fact due to a bug in IntelliCad?
Change Font and it's okay.
Bricscad - no font issue, so I always assume it's an Intellicad problem but haven't seen any fix for it.
Posted : August 9, 2014 11:11 pm
