Carlson merge tins
Tiglinda
(@tiglinda)
I am trying to merge to overlapping tin files. I am using the merge tin command under tin utilities but am not getting consistent results. The first to tins merged ok, but it is not working when I add the 3rd tin. I am trying to use the wipe and overwrite command but I am only getting the area of the second tin as a result. I am not sure what I did to get it to work the first time. Any idea what is not working?
Thanks.
Posted : December 10, 2012 3:06 pm
ladd-nelson
(@ladd-nelson)
Without knowing the exact steps you are following, my recommendation would be to run multiple instances of the Merge routine:
Existing1 + Proposed1 = Merged1
Then, run a second instance of the routine where the "existing" is the result of the first pass:
Merged1 + Proposed2 = Merged2
etc, repeat as needed. Does this help?
Posted : December 10, 2012 5:11 pm
jef221
(@jef221)
Hi Ladd, just wanna say thank you for being a helpful member in this forum, I always notice you extending assistance to surveyors in need, even if it's free and already way beyond your official duties in Carlson. Good job !! :good: :good:
Many thanks as well to all members who help and share their techniques & experience, you guys are the reason why this forum is a great source of surveying knowledge.
:good: 🙂
Posted : December 11, 2012 5:07 am
Tiglinda
(@tiglinda)
Thanks Ladd.
I tried it again this morning and it worked. In the merge tin dialogue box it was turning most of the surface red, which I took to mean it was erasing based on previous experience. I saved it anyway and it worked fine.
Posted : December 11, 2012 7:23 am
