Carlson
10 Users
I frequently enter deeds using the "enter deed description" and I would like to be able to have the program default to the last entered bearing so that I dont have to reenter it everytime I am going along a line with multiple points, It would be a nice feature.
Posted : October 26, 2012 5:16 am
(@kris-morgan)
I've used that routine a time or two and don't like the fact that it assigns point numbers. Instead, I draw the deed using 2dp, rotate and translate it, pick the points I want, and assign values based on that. It seems WAY faster also.
Posted : October 26, 2012 5:25 am
(@glenn-breysacher)
Kris,
There's a box that can be unchecked on the "Enter Deed Description" dialog box so that it DOESN'T draw points, only lines and annotation.
Posted : October 26, 2012 5:30 am
(@shawn-billings)
I use Extend by Distance. I draw a 2d polyline and rotate it to my first bearing and then extend by distance, Extend by Distance then lets me enter the bearings and distances for the remaining work. I should probably look into the deed entry though.
Posted : October 26, 2012 5:39 am
(@kris-morgan)
> Kris,
I saw that a few years ago and was already used to doing it the other way. It's almost intuitive the way I draw the deeds with lines
2dp
click somewhere
d enter distance enter a enter quadrant enter bearing enter voila, line is drawn and after I got used to it, 20 call descriptions take a few minutes.
Posted : October 26, 2012 5:40 am
 jph
(@jph)
That's sounding more complicated than the Enter Deed Description command.
It's the Create Lots routines that I find annoying, that you're forced to create point numbers. I usually put them up around 100000, and delete them later.
Posted : October 26, 2012 6:27 am
(@spledeus)
i do the same, but PDD with only the deed information
i want to monkey with the record information before i make points or annotation
Posted : October 26, 2012 6:28 am
 RFB
(@rfb)
Doesn't the UP arrow key repeat previous keystrokes?
Posted : October 26, 2012 7:02 am
(@ladd-nelson)
I've passed this information along to the Carlson development team and have been told it is on the To Do list.
Posted : October 26, 2012 8:09 am
(@pin-cushion)
COGO > LINE BY ANGLE DISTANCE
... USE THIS AND YOU WILL NOT GET POINT NUMBERS JUST THE LINES
Posted : October 26, 2012 10:26 am
(@glenn-breysacher)
> > Kris,
> 2dp
> click somewhere
I have not used that command, seems pretty handy. However, you don't get annotations on your lines like Enter Deed Description (which you can also turn off).
Posted : October 29, 2012 6:08 am
 jph
(@jph)
I'm talking about the lot file - creating a "lot" from lines/polylines that are already in the dwg. The routine assigns point numbers to endpoints that don't already have them.
Posted : October 29, 2012 6:20 am
(@foggyidea)
I use it all the time to enter plans, I did "complain" sometime ago about the difference between using the cogo> commands vs. the "enter by deed", for instance, in "enter by ded, the quadrant is part of the bearing entry and the cogo comamnd it's a seperate first entry...
but in the cogo command it's not as easy to enter the curve data...
Posted : October 29, 2012 6:29 am
 jph
(@jph)
I don't like the curve entry in the Enter Deed routine. It doesn't always make it tangent to the line coming from the curve (how could it) - off by a few seconds sometimes.
I always go off to the side and make the two bearings coming in and out, and then fillet with the radius - and then move the curve to where it belongs. It takes longer, but it makes them tangent.
Posted : October 29, 2012 6:38 am
(@kris-morgan)
Glenn, typically, when making composites of deeds, especially when working on the grid, is that I will draw the commands, autoann the linework, then rotate and translate the annotation and linework into the master composite. It will make a line table and I can, as the offspring suggested, keep em separated. It works for me, may not for everyone. I dig it though. 🙂
Posted : October 29, 2012 6:48 am
(@glenn-breysacher)
Hey, if it works for you, "keep 'em separated". I love the Offspring.
Posted : October 29, 2012 7:21 am
(@glenn-breysacher)
Ladd,
Another wish list item for "Enter Deed Description" is to have a prompt for a description/annotation for a corner, even though you don't want to create points.
Posted : October 29, 2012 10:14 am
