Carlson 2012 - change elevations
7 Users
 ppm
(@ppm)
I am running Carlson 2012 and drafted a topo. Everything has x,y, and z values. The architect and engineer what everything (lines, symbols, text etc) in the .dwg at zero elevation. I tried to do the old
Change
and type in "0" but it says: "Cannot change elevation of objects with differing Z coordinates."
I remember this being frustrating when I was running LDD (10 yrs ago), but now I need to do it in Carlson (2012). Any help?
Posted : 08/08/2013 12:45 pm
(@stephen-ward)
Try the FLATTEN command. I know it works in AutoCAD 2013, not sure about the embeded or Intellicad versions.
Posted : 08/08/2013 1:00 pm
Maybe "change polyline elevations", or "3D entities to 2D"
Posted : 08/08/2013 4:24 pm
 RFB
(@rfb)
Does 2012 have the DRAWING CLEANUP routine?
If so, there is a box in there:
SET ELEVATIONS OUTSIDE RANGE TO ZERO
I'd set the the range to 20000 min and 21000 max, this should change everything to zero elevation. (in my state anyway)
Posted : 09/08/2013 4:55 am
(@foggyidea)
I believe you're going to have to check your point defaults to make sure that the "locate on Real Z axis" is turned off, and reprocess your points.
Posted : 09/08/2013 5:12 am
(@roadburner)
Yup, "3D Entity to 2D". (In the edit pulldown)
Posted : 09/08/2013 7:10 am
(@roadburner)
Not....
Posted : 09/08/2013 7:12 am
(@kris-morgan)
Tell that ignorant SOB to do it himself since he's gonna molest your data anyway.
Posted : 09/08/2013 8:11 am
 ppm
(@ppm)
Thank you all for your suggestions, but thank you especially Kris. Love that answer. I was out of town a while but I will give some of these a shot here later today.
Posted : 12/08/2013 12:02 pm
