I have Carlson 2010 w/Intellicad. I have somehow buggered up a setting. I used the "Extend Line By Distance" command quite often, and somehow I got something toggled that it will create a node(?) or a grip at every extension. It didn't used to do that. Maybe it's just my OCD, but I really can't stand that it does that now.
Any help is appreciated.
TIA
Carl
EXTENDEDGRIPS
0=OFF
1=ON
Steve
That doesn't work. 🙁
In the Edit -- Extend -- Extend by Distance command, check the "V" option (per the Command Help):
>V - Vertex mode Toggles insertion of co-linear vertices.
THAAAAAAAAAAAAAAAAAAAANK YOOOOOOOOOOOOOOU!!!!!!!!!!!!!!
Carl
Ladd,
I even called Carlson this morning and you would have thought that I was speaking in an alien language for as much as the person who kept interrupting me and telling me that there was no way to know how to fix this.
Carl
You're welcome. I don't use that command all that often and the solution was provided (graciously) from Lon Watson in the Carlson Technical Support Group. I learned something new today, too.
I'm willing to bet that I got ahead of myself somewhere, got sloppy, and was trying to do a "ctrl+V" and toggled it.
In any case, again, thank you and Lon very much.
Carl
Yep, tech support has gone way down hill, everywhere.
The Ladd-Lon team strikes again!
