Carlson 2008 Contouring Question
jimmy-cleveland
(@jimmy-cleveland)
I am working on a topographic survey. I have created the surface, and am swapping tin edges to smooth out some of the contours.
It seems like Carlson used to redraw the contours after I swapped a tin edge, so I could see how it affected the contour. Today, I must have a setting wrong, because I the contours are not redrawing after I swap the tin edges.
Any help is greatly appreciated.
Jimmy
Posted : February 13, 2013 7:27 pm
spledeus
(@spledeus)
Did you Write a Triangulation File?
Posted : February 13, 2013 8:21 pm
jimmy-cleveland
(@jimmy-cleveland)
Yes
Posted : February 13, 2013 8:37 pm
Check the boxes that say:
draw contours
erase previous contours
Posted : February 13, 2013 8:40 pm
jimmy-cleveland
(@jimmy-cleveland)
Those boxes were checked. I don't know what was wrong.
I created a new tin file, and after that, everything worked just fine. Not sure what was going on. It was weird, because I had created the surface on my desktop, and was having the problem. I then migrated back to the house, and worked on it on the laptop, and had the same issue. Something in the tin file must have been corrupted.
Thanks for the tips.
Jimmy
Posted : February 14, 2013 8:15 am
