batch zip code lookup
7 Users
(@andy-j)
In massaging my project database, I see that many of my projects are missing data in the fields of "city" and/or "zip Code" (the problem with working in such a limited geography.... we tend to not even think of what city a project is in)
While probably 95% of my projects are within two zip codes, I'd like to clean up some of this old data before I begin mapping it for research.
I have street addresses, and a fairly small sample of cities that they might be in. (usually one of two or maybe three) .
Anyone have a spreadsheet or online source for batch zip coding?
Andy
Posted : 05/07/2013 8:33 am
(@threerivers)
I could send you an old copy of "Zip4" but Florida has so many
new 34XXX codes. It would not be useful. I am sure there is some
shareware out there.
Posted : 05/07/2013 10:24 am
Maybe usps.com ?
Posted : 05/07/2013 1:58 pm
 BigE
(@bige)
I have a database with over 42k known zip codes.
It is a SQL server database but I might be able to export it to an Excel sheet.
I'll have to investigate.
Posted : 05/07/2013 3:37 pm
(@ralajer)
You could try http://www.findlatitudeandlongitude.com/batch-geocode/ . I used it to get the lat and longs for a few hundred intersections and it worked fairly well. I just did some limited testing to see if it would return a full address from a partial(no city or zip code) address and it worked on all of my limited sample. I did have to add the state to limit the search to a region; however, you could probably add the county to further limit region.
Posted : 05/07/2013 5:24 pm
Does this help?
Also, I typed 33034 into googlie and clicked on maps and got this.....
Posted : 05/07/2013 6:25 pm
(@andy-j)
Thanks! I think this is just what I was looking for.
Posted : 07/07/2013 10:38 am
 vern
(@vern)
Apparently there is a system to the zip codes. A man named Ben Fry developed an interactive map many years ago called zipdecode. I googled but the map didn't want to work for me just now, I have used it before though.
Posted : 08/07/2013 8:02 am
