AutoCad Xref
8 Users
(@jms66)
Trusted Member Registered
Working in Autocad 2010, while creating 3d polylines over an attached xref contract
drawing, I clearly see the polylines that I am creating, I save the drawing
and returned to continue working on the drawing at a later date, and now the xref is ontop of my newly created polylines whereas I cannot see those polylines that I previously created unless I unload that xref, Is there a command that tells the autocad xref whether it should be ontop or below the current drawing..? If not any other suggestions..?
Thanks
** moved to CAD/Software/Computers **
Posted : 02/09/2014 6:53 am
(@jimmy-cleveland)
Go to display options and click the send to back option. Then select the xref, and it should "go behind" your new lines.
Posted : 02/09/2014 6:58 am
(@davidgstoll)
Honorable Member Registered
JMS66,
You can use Display Order by right-clicking on the XREF.
Dave
Posted : 02/09/2014 7:00 am
or if you're into typing commands...draworder
(@jms66)
Thank you Jimmy, David & Paden
Your timely help is greatly appreciated...
Posted : 02/09/2014 7:13 am
Illustrious Member Registered
6 minutes: try and find that; anywhere else on the internet!B-)
Posted : 02/09/2014 7:32 am
 BigE
(@bige)
Famed Member Registered
Yeah. As Brad Ott likes to say:
BEER LEG ROCKS!
Posted : 02/09/2014 8:26 am
(@geoff-ashworth)
draworder command is also dr if you only want to type 2 letters.
Posted : 03/09/2014 7:08 am
(@arctanx-2-2)
Hey Dave, how did you change your menu color to green?
Posted : 03/09/2014 2:33 pm
Share:
