I'm pretty sure you can do this, but can't find it.
I'd like to scale down about 20 sequential numbering for lots.
I'm trying to rescale them without a base point, so they remain in their position.
Thanks,
Forrest
Posted : August 18, 2011 5:14 am
Under points pull-down, resize point attributes
Posted : August 18, 2011 5:17 am
Thanks David, but they are not a point attribute, they more in line with a text and a circle.
If I rescale them using regular scale with a base point it will move them together. I'm just trying to avoid moving them back into place.
thanks
Posted : August 18, 2011 5:35 am
Try "Properties" select items you want to "scale" change "x", "y", & "z" scale, should do it at the "insertion point. Worth a try.
Posted : August 18, 2011 5:39 am
Sorry about that, I misread your post. Doug's suggestion will work.
Posted : August 18, 2011 5:56 am
