Acad Help with Toolbars
(@larry-best)
Someone stole my toolbars last night.
How do I get them back?
Land Desktop 2007
Posted : October 27, 2010 5:06 am
(@robert-locke)
Depending on your version I believe the command is "menu", you get a lot of choices from there.
Posted : October 27, 2010 5:17 am
I Have Them, And The Ransom Is ?
Posted : October 27, 2010 5:21 am
(@larry-best)
"Menu" gets me to
Enter customization file name or [. (for none)] <C_Documents and
SettingsBestApplication DataAutodeskAutodesk Land Desktop
2007R17.0enuSupportLand>:
Then what
Posted : October 27, 2010 5:37 am
Type in "toolbar?"
Posted : October 27, 2010 5:40 am
(@robert-locke)
Its been awhile since I was chained to a computer, possibly "menuload" is what I should have told you. I think you can also right click the mouse on the appropriate area of the screen and achieve the same thing.:-) If those don't work I apologize for steering you in the wrong direction. The mind is a terrible thing to lose.:-)
Posted : October 27, 2010 5:49 am
(@larry-best)
Paden,
Toolbar gets me Customize User Interface.
Under Toolbars the ones I need (Layer, Layer 2, and Osnap) aren't there.
I found them under Partial CUI Files ACAD Toolbars. And in Appearance On by Default they're all on SHOW.
Could they have slid off the screen?
Posted : October 27, 2010 6:02 am
May be..that's happened to me at least once. I also remember an occurance that a few of the toolbars didn't appear to be 'up'...but when I would minimize and maximize the entire acad window, there were visible for just a brief second...things that make you go 'hmmmm...'.
I believe I just bailed out of the file and rebooted. Good luck.
Posted : October 27, 2010 6:10 am
 RFB
(@rfb)
I had recently, totally screwed up my toolbars.
I then proceeded to make matters worse by hacking around with my menus.
After a half a day of reading and more screwing around, I did a Windows System Restore to a couple of weeks ago.
Problem Solved!
:coffee:
Posted : October 27, 2010 6:11 am
Right click within the light gray area of any toolbar?
Posted : October 27, 2010 6:15 am
