Which company you will choose topodrone or teokit. eu? Seems their systems to be the same.
I added BATAM PPK to a P4 Pro 2.0 and would not recommend it. Add ons are cumbersome and rob too much flight time. You want to buy it? It's been on the shelf.
The P4RTK is well the money.
Not sure why you think post processing takes too much time. For me it takes 5 to 10 minutes including exchanging data from the card. Depending on where you are located, most areas I fly have cell service an there access to a VRS, so Network RTK is used successfully.?ÿ
Suggest you get comfortable post processing PPK.?ÿ
Do you have a VRS in your area?
Is cell coverage good in your area?
You still need GCP's. Just fewer. I use 3 to 5. One is a target under my base.
yes here in Europe we have perfect coverage of cell phone. ?oh ask about using rtk?
my field are 5000- 40000 m2 so if it still needs Gcp are a pain. I was thinking to use a PPK system in order not to put spread gcp in the ground all the time.?ÿ
@leegreen from your experience how accurate are the geotagging of fotos 2-3 cm horizontal and 10cm vertical?
Anyone else that use that systems ?
