GOOD EVENING FROM TORONTO
I am trying to connect my trimble R6 GPS base with trimark 3 external radioI am using ioioi 2 port from gps base station to connect radio the radio screen is blinking and i can’t change frequency i didn’t use external radio Before it’s my first setting i am attaching the pictures of my set up may be i missing some thing
If anyone help it’s appreciated
Dropbox File (Private or Invalid)
Here is more or less what my reply was...
Make sure baud rate and format is set the same in the receiver and the radio. Also the over-the-air format (Trimtalk, etc) need to be set.
I always carry a small UHF radio when doing RTK to troubleshoot. You can get one on Amazon (Baofeng) for around $20. Just make sure it has the frequencies used in your country. In the US I use 464 Mhz
