Trimble DL App & Lo...
Trimble DL App & Logging Static
7 Users
gbunk
(@gbunk)
We have a pair of old Trimble R6's that haven't been used for awhile. I'd like to start using them as static units. I see Trimble has the Trimble DL App to make static logging simple.?ÿ Assuming the units have appropriate firmware to connect & work, what can I expect using the app? Can I start one unit with my phone, then disconnect from it to go setup & connect to the 2nd unit? I think I read somewhere that the DL App requires you to stay connected to the receiver during the duration of the survey, is this correct? If so, then how do you start multiple receivers to collect at the same time?
I also have a Ranger 3 running Survey Pro with our SP80 receivers. Can I start logging static with it without going thru receiver configuration as base or rover? Any tips on this??ÿ I'm used to Carlson SurvCE where I could just connect to any receiver at any time to start/stop static logging without any interference with the RTK survey. I've even installed SurvCE in demo mode on another data collector just to use it for that purpose - think that's the better way to go this time around too?
Thanks,
-Garry
Posted : March 12, 2019 5:55 pm
Johnson5144
(@johnson5144)
The app information on the Google Play Store is a bit misleading as it states the R6 is supported, but Trimble responds to a review and states ƒ??Trimble DL supports GNSS receivers with FW 4.64 and higher. This means you need a Trimble R8 Model 2 or newer.ƒ?
Posted : March 12, 2019 6:45 pm
gbunk
(@gbunk)
I saw that and assumed an R6 could have firmware 4.64 or higher, so it can't??ÿ
Any comment on Survey Pro's ability/use!
-Garry
Posted : March 12, 2019 7:02 pm
gbunk
(@gbunk)
I just checked Trimble's website and I see the same firmware available for an R8 is also for an R6.?ÿ The catch seems to be that to upgrade firmware you have to have an active warranty (though I'm not sure how this is detected). I guess I'll just have to see what firmware version is currently installed .
-Garry
Posted : March 12, 2019 7:10 pm
sireath
(@sireath)
You have to check the firmware of your receiver to see if it is compatible. I am using R4 Model 3 FW 4.81 for reference.?ÿ
My workflow is to let my receivers sit static and record into the receiver. When all are done at the end of the day, I fire up the app and connect one by one via bluetooth and download the static files and email them out. Saves the hassle of finding and messing around with cables and windows mobile sync.?ÿ
Posted : March 12, 2019 9:39 pm
gbunk
(@gbunk)
Ah, so you can disconnect your phone and the unit will still record?
-Garry
Posted : March 13, 2019 9:47 am
sireath
(@sireath)
Yes but initially i do not conenct to the app at all. My receivers have been set to record when it powers on. So it will store in the internal battery. if you use the app to power on and start recording, it will record into the app.
Posted : March 13, 2019 6:23 pm
gbunk
(@gbunk)
Well that's stupid recording to the app (and hence needing to leave your phone at the unit).
Today I tested the app with the R6 and it let me do everything except record. It kept saying "PDOP Unavailable" which I think is Trimble secret code for "your firmware is too old".
I then tried using Survey Pro to start & stop a static session and it worked perfectly. It didn't interrupt my RTK session with the other unit was pretty logical with the workflow. I had installed Fast Survey (Carlson SurCE in disguise) as a demo, but it doesn't have any Trimble units in its listing.?ÿ
-Garry
Posted : March 13, 2019 7:59 pm
I used Trimble DL to perform static for almost 2 years. It never 'stored to the app'.
Posted : March 14, 2019 8:53 am
lee-d
(@lee-d)
You can easily configure the R6 to start logging when powered up regardless of the firmware version.
Posted : March 14, 2019 12:37 pm
scotland
(@scotland)
PDOP is The Position Dilution of Precision (PDOP) is likely one of the most critical GPS AutoTrac values to monitor. As the PDOP value increases, both the horizontal and vertical precision (guidance accuracy) of your data points decreases.
Posted : March 14, 2019 8:08 pm
gbunk
(@gbunk)
Scott, yes I know. It was meant to be a joke. Clearly the app should have shown me PDOP as it was showing that I was tracking 14 satellites.
-Garry
Posted : March 14, 2019 8:34 pm
scotland
(@scotland)
Sorry...  I didn't pick up on the joke.
I've used the DL app once.  Just started the reciever up.  Most have been setup to record once turned on.  You have to stop the recording to retrieve the file.   So power down and back on.  Connect DL and choose the file and email it.
Posted : March 15, 2019 8:34 pm
david-kendall
(@david-kendall)
Posted by: @lee-d
Anyone know the easiest way to configure this?
Posted : November 23, 2021 4:04 pm
