trimble 4000 series...
trimble 4000 series internal memory
Dane Mince
(@danemince)
I wonder if anyone has an idea about how much data can be logged with?ÿ 256k or 512k internal memory at 15 sec iintervals? Any info on how to add more memory? thanks for your help?ÿ
Posted : September 15, 2019 2:41 pm
I don't recall log times, but adding memory requires access to dealer software, unless there's a hack out there that I'm not aware of.
Posted : September 15, 2019 9:06 pm
stephen-ward
(@stephen-ward)
Mine show 512 k+ 256k + 256k at start up.?ÿ I'm assuming that means 512k on the main board + 2 add on modules of 256k each.?ÿ Under status it claims at 8sv's @ 15 second interval it can store 23 hours of data.
Posted : September 15, 2019 11:29 pm
Dane Mince
(@danemince)
1024k?ÿ SW?ÿ seems plenty.?ÿ
Posted : September 16, 2019 8:31 am
fenugrec
(@fenugrec)
Posted by: @jim-frame
Of course assuming the hardware is actually installed, all the options can be changed from the front panel (or a "customized" version of the firmware update tool).
On mine, also with 512+256+256, it says 5718 epochs @ 8 SVs, so around 184 bytes per epoch. That said, if you disable L2 I think you can log for longer, but the unit should tell you for sure on the Control->Logged data files page.
Posted : November 2, 2019 9:30 pm
