SOPAC GPS Explorer ...
SOPAC GPS Explorer Time Series Plots
2 Users
I'm no longer able to see the time series plots in GPS Explorer. I don't know how long it's been since this last worked -- I don't review time series very often -- but even when I run Internet Explorer 11 I can't load the time series images. Anybody else having this problem?
Thanks!
Posted : November 5, 2017 5:48 pm
dragan
(@dragan)
Hi,
Also, I can not see the satellite timetable for some time. I use Leica 1200, and LGO.
The plot is empty. I thought that the reason I still use the older version of software 4.0.
The OS that I use is XP on that computer, which is not on the Internet.
Posted : November 13, 2017 3:54 pm
The staff at SOPAC figured this out for me: the time series plots require 32-bit Java, and I had the 64-but version installed. Once I switched to the 32-bit version the plots appeared.
Posted : November 13, 2017 4:09 pm
dragan
(@dragan)
Jim Frame, post: 455346, member: 10 wrote: The staff at SOPAC figured this out for me: the time series plots require 32-bit Java, and I had the 64-but version installed. Once I switched to the 32-bit version the plots appeared.
Jim, Thank you very much.
All the best
Posted : November 15, 2017 3:33 pm
