RTK networks and co...
RTK networks and continental drift
mark-o
(@mark-o)
Do RTK networks compensate for drift and if not what is typically done do address it?
Posted : April 9, 2018 10:25 pm
From some of my readings it seems like they do. Which of course means, that if you rely on them, you need to figure out how to make your data drift with them, or compensate some other way.
Posted : April 10, 2018 6:50 am
lee-d
(@lee-d)
Louisiana holds to the current NGS epoch, which is NAD83 (2011.00). Every network operator has the option of how to handle this, you'd have to contact the network administrator in question. To me it makes sense to align with NGS.
Posted : April 10, 2018 6:58 am
?ÿTo good accuracy in the US, this is the difference between WGS84/IGS08 and NAD83, except for those on the Pacific coast.
There may be differences in what VRS networks broadcast.?ÿ If you can get to valid NAD83 coordinates in most of the US you have compensated for continental?ÿ drift.
The compensation procedure will change a little with the 2022 datum, but will be even better.
Posted : April 10, 2018 7:01 am
mark-o
(@mark-o)
I appreciate all the replies. Up here in the northeast, I don't believe we drift as much as folks out west (I want to say the North American plate is more or less rotating up and away towards the north pole). But regardless, it's kept me wondering/worrying. I feel a little better now. 🙂
Posted : April 10, 2018 1:08 pm
Try Trimble Business Center free for 21 days. Get started.
lee-d
(@lee-d)
Gavin -
I looked at two coastal stations on NGS and everything published referenced 2011.00 - what's an example of a station that's been updated? Or do they not change the epoch date? That wouldn't make sense to me.
Posted : April 10, 2018 1:10 pm
spmpls
(@spmpls)
NGS has not updated the datasheets for CORS positions for the stations on the "Left Coast", but most RTN operators do, as needed, in some manner similar to what Gavin described for Washington. The entire California Spatial Reference System, approximately 900 active continuous GPS stations (plus some historical stations that are no longer active), was recently updated to Epoch 2017.50. This included the subset of stations that comprise the California Real Time Network (CRTN). I have attached the Project Report for reading pleasure.
All the data can be accessed here:
http://csrc.ucsd.edu/CSRC_Epoch2017_50.shtml
Posted : April 10, 2018 1:31 pm
Posted by: Lee D
Gavin -
Actually the NAD83(2011) reflects the realization, the Epoch date is still 2010.0000.
I prefer to use the "Position and Velocity" link (as opposed to the Data Sheet), because it provides additional data:
?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ ***IGS 08***
?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ EGAN_BRGN_NV1996 (EGAN),?ÿ NEVADA
Retrieved from NGS DataBase on 06/05/17 at 15:26:52.
_____________________________________________________________________________
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ Antenna Reference Point(ARP): EGAN_BRGN_NV1996 CORS ARP?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ -------------------------------------------------------?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ PID = AI0950?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| IGS08 POSITION (EPOCH 2005.0)?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| Computed in Aug 2011 using data through gpswk 1631.?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ X =?ÿ -2083234.248 m?ÿ?ÿ?ÿ?ÿ latitude?ÿ?ÿ?ÿ =?ÿ 39 20 42.87822 N?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Y =?ÿ -4479986.399 m?ÿ?ÿ?ÿ?ÿ longitude?ÿ?ÿ = 114 56 19.87547 W?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Z =?ÿ?ÿ 4023298.002 m?ÿ?ÿ?ÿ?ÿ ellipsoid height = 1998.362?ÿ?ÿ m?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| IGS08 VELOCITY?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ VX =?ÿ -0.0172 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ northward =?ÿ -0.0095 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ VY =?ÿ?ÿ 0.0022 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ eastward?ÿ =?ÿ -0.0165 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ VZ =?ÿ -0.0080 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ upward?ÿ?ÿ?ÿ =?ÿ -0.0010 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| NAD_83 (2011) POSITION (EPOCH 2010.0)?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| Transformed from IGS08 (epoch 2005.0) position in Aug 2011.?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ X =?ÿ -2083233.560 m?ÿ?ÿ?ÿ?ÿ latitude?ÿ?ÿ?ÿ =?ÿ 39 20 42.86062 N?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Y =?ÿ -4479987.668 m?ÿ?ÿ?ÿ?ÿ longitude?ÿ?ÿ = 114 56 19.82710 W?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Z =?ÿ?ÿ 4023298.005 m?ÿ?ÿ?ÿ?ÿ ellipsoid height = 1999.030?ÿ?ÿ m?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| NAD_83 (2011) VELOCITY?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| Transformed from IGS08 velocity in Aug 2011.?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ VX =?ÿ -0.0003 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ northward =?ÿ?ÿ 0.0010 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ VY =?ÿ?ÿ 0.0028 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ eastward?ÿ =?ÿ -0.0015 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ VZ =?ÿ -0.0007 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ upward?ÿ?ÿ?ÿ =?ÿ -0.0023 m/yr?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|_____________________________________________________________________________|
| L1 Phase Center of the current GPS antenna: EGAN_BRGN_NV1996 CORS L1 PC C?ÿ?ÿ |
| -------------------------------------------------------------------------?ÿ?ÿ |
| The Dorne Margolin with chokerings, Model 59 antenna?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| (Antenna Code = TRM59800.80?ÿ?ÿ?ÿ?ÿ SCIS) was installed on 15Mar2017.?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ The L2 phase center is 0.029 m above the L1 phase center.?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ PID = DQ5170?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ X =?ÿ -2083234.276 m?ÿ?ÿ?ÿ?ÿ latitude?ÿ?ÿ?ÿ =?ÿ 39 20 42.87825 N?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Y =?ÿ -4479986.459 m?ÿ?ÿ?ÿ?ÿ longitude?ÿ?ÿ = 114 56 19.87546 W?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Z =?ÿ?ÿ 4023298.057 m?ÿ?ÿ?ÿ?ÿ ellipsoid height = 1998.449?ÿ?ÿ m?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| The IGS08 VELOCITY of the L1 PC is the same as that for the ARP.?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ X =?ÿ -2083233.588 m?ÿ?ÿ?ÿ?ÿ latitude?ÿ?ÿ?ÿ =?ÿ 39 20 42.86064 N?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Y =?ÿ -4479987.728 m?ÿ?ÿ?ÿ?ÿ longitude?ÿ?ÿ = 114 56 19.82709 W?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Z =?ÿ?ÿ 4023298.061 m?ÿ?ÿ?ÿ?ÿ ellipsoid height = 1999.117?ÿ?ÿ m?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| The NAD_83 (2011) VELOCITY of the L1 PC is the same as that for the ARP.?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ Monument: EGAN_BRGN_NV1996 GRP?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ ------------------------------?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ PID = DG5303?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ Inscribed: NONE?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ X =?ÿ -2083234.220 m?ÿ?ÿ?ÿ?ÿ latitude?ÿ?ÿ?ÿ =?ÿ 39 20 42.87822 N?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Y =?ÿ -4479986.338 m?ÿ?ÿ?ÿ?ÿ longitude?ÿ?ÿ = 114 56 19.87547 W?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Z =?ÿ?ÿ 4023297.947 m?ÿ?ÿ?ÿ?ÿ ellipsoid height = 1998.276?ÿ?ÿ m?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| The IGS08 VELOCITY of the monument is the same as that for the ARP.?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ X =?ÿ -2083233.532 m?ÿ?ÿ?ÿ?ÿ latitude?ÿ?ÿ?ÿ =?ÿ 39 20 42.86062 N?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Y =?ÿ -4479987.607 m?ÿ?ÿ?ÿ?ÿ longitude?ÿ?ÿ = 114 56 19.82710 W?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
|?ÿ?ÿ?ÿ?ÿ Z =?ÿ?ÿ 4023297.951 m?ÿ?ÿ?ÿ?ÿ ellipsoid height = 1998.944?ÿ?ÿ m?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ |
| The NAD_83 (2011) VELOCITY of the monument is the same as that for the ARP. |
* Latitude, longitude and ellipsoid height are computed from their
?ÿ?ÿ corresponding cartesian coordinates using dimensions for the
?ÿ?ÿ GRS 80 ellipsoid: semi-major axis = 6,378,137.0 meters
?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ flattening = 1/298.257222101...
* WARNING: Mixing of antenna types can lead to errors of up to 10 cm.
?ÿ?ÿ in height unless antenna-phase-center variation and antenna-phase-center
?ÿ?ÿ offset are properly modeled.?ÿ See next comment.
* The coordinates shown on this page were computed using absolute antenna
?ÿ?ÿ calibrations.?ÿ CORS coordinates began using absolute antenna calibrations
?ÿ?ÿ beginning with IGS08 and NAD 83 (2011, MA11, PA11).?ÿ For additional
?ÿ?ÿ information on the derivation of these positions and velocities and
?ÿ?ÿ antenna calibrations consult:
?ÿ?ÿ http://geodesy.noaa.gov/CORS/coords.shtml
?ÿ?ÿ http://geodesy.noaa.gov/ANTCAL
* For more site specific information on the equipment history and
?ÿ?ÿ monumentation type consult:
?ÿ?ÿ ftp://geodesy.noaa.gov/cors/station_log/egan.log.txt
?ÿ?ÿ http://geodesy.noaa.gov/cgi-cors/corsage_2.prl?site=egan
* The NAD_83 position & velocity were revised in July 2000.
* The NAD_83 position & velocity were revised in Mar. 2002.
* The position & velocity were revised in Aug 2011.
Posted : April 10, 2018 2:28 pm
spmpls
(@spmpls)
Ours are moving a little faster than that.?ÿ
                      ***IGS 08***
                MILLSCREEKCN2007 (P176),  CALIFORNIA
 Retrieved from NGS DataBase on 10/19/17 at 15:29:19.
|         Antenna Reference Point(ARP): MILLSCREEKCN2007 CORS ARP             |
|                             PID = DN7542                                    |
| IGS08 POSITION (EPOCH 2005.0)                                               |
| Computed in Apr 2012 using 29 days of data.                                 |
|     X =  -2712719.292 m     latitude    =  37 28 18.37726 N                 |
|     Y =  -4281638.063 m     longitude   = 122 21 25.69787 W                 |
|     Z =   3859341.980 m     ellipsoid height =  433.818   m                 |
| IGS08 VELOCITY                                                              |
| Predicted with HTDP_3.1.2 Apr 2012.                                         |
|     VX =  -0.0237 m/yr      northward =   0.0213 m/yr                       |
|     VY =   0.0303 m/yr      eastward  =  -0.0362 m/yr                       |
|     VZ =   0.0169 m/yr      upward    =   0.0000 m/yr                       |
| NAD_83 (2011) POSITION (EPOCH 2010.0)                                       |
| Transformed from IGS08 (epoch 2005.0) position in Apr 2012.                 |
|     X =  -2712718.627 m     latitude    =  37 28 18.36834 N                 |
|     Y =  -4281639.180 m     longitude   = 122 21 25.65069 W                 |
|     Z =   3859342.083 m     ellipsoid height =  434.347   m                 |
| NAD_83 (2011) VELOCITY                                                      |
| Transformed from IGS08 velocity in Apr 2012.                                |
|     VX =  -0.0074 m/yr      northward =   0.0344 m/yr                       |
|     VY =   0.0307 m/yr      eastward  =  -0.0227 m/yr                       |
|     VZ =   0.0265 m/yr      upward    =  -0.0013 m/yr                       |
| L1 Phase Center of the current GPS antenna: MILLSCREEKCN2007 CORS L1 PC C   |
| The Dorne Margolin with chokerings, Model 59 antenna                        |
| (Antenna Code = TRM59800.80     SCIT) was installed on 26Jan2015.           |
|        The L2 phase center is 0.033 m above the L1 phase center.            |
|                             PID = DQ6459                                    |
|     X =  -2712719.327 m     latitude    =  37 28 18.37730 N                 |
|     Y =  -4281638.120 m     longitude   = 122 21 25.69783 W                 |
|     Z =   3859342.032 m     ellipsoid height =  433.903   m                 |
| The IGS08 VELOCITY of the L1 PC is the same as that for the ARP.            |
|     X =  -2712718.661 m     latitude    =  37 28 18.36838 N                 |
|     Y =  -4281639.237 m     longitude   = 122 21 25.65065 W                 |
|     Z =   3859342.136 m     ellipsoid height =  434.432   m                 |
| The NAD_83 (2011) VELOCITY of the L1 PC is the same as that for the ARP.    |
|         Monument: MILLSCREEKCN2007 GRP                                      |
|                             PID = DN7544                                    |
|         Inscribed: UNKNOWN                                                  |
|     X =  -2712719.288 m     latitude    =  37 28 18.37726 N                 |
|     Y =  -4281638.058 m     longitude   = 122 21 25.69787 W                 |
|     Z =   3859341.975 m     ellipsoid height =  433.810   m                 |
| The IGS08 VELOCITY of the monument is the same as that for the ARP.         |
|     X =  -2712718.623 m     latitude    =  37 28 18.36834 N                 |
|     Y =  -4281639.174 m     longitude   = 122 21 25.65069 W                 |
|     Z =   3859342.078 m     ellipsoid height =  434.339   m                 |
   offset are properly modeled.  See next comment.
   calibrations.  CORS coordinates began using absolute antenna calibrations
   beginning with IGS08 and NAD 83 (2011, MA11, PA11).  For additional
   ftp://geodesy.noaa.gov/cors/station_log/p176.log.txt
    http://geodesy.noaa.gov/cgi-cors/corsage_2.prl?site=p176
 * The position & velocity were revised in Apr 2012.
Posted : April 10, 2018 2:42 pm
Posted by: SPMPLS
                      ***IGS 08***
|                             PID = DN7542                                    |
| IGS08 VELOCITY                                                              |
|                             PID = DQ6459                                    |
|                             PID = DN7544                                    |
Of course I know that, my point simply being that there is a lot of additional information on that sheet, than the "Data Sheet" (including the origin of the velocity estimate).
Posted : April 10, 2018 3:38 pm
Trimble Business Center — Know your data is right. Start free trial.
lee-d
(@lee-d)
2011.00 was a typo my bad. Meant 2010.00
Posted : April 10, 2018 3:46 pm
