Hi colleagues.
I will be glad to receive some help about the following issues while processing with Leica Infinity.
1.- How to change the measuremet interval while importing data, lets say from 1 s to 30 s?.
2.- How and where to edit the RINEX header information for exporting data?
Both issues were rather easy to carry out on Leica Geo Office, but I can not find the way to do it with Infinity.
Best regards,
Ernesto
Speak with your sales rep. or call the Leica Tech Support line.?ÿ They should be able to walk you through it.
Well, I'm baffled.?ÿ Not much info in the help files.?ÿ I have not exported a Rinex file since I started using Infinity several years ago.?ÿ As Chris pointed out, I would contact Leica support.?ÿ As for importing at a specified interval, I'm sure you could do it at one point but I cannot find that option on the current version.?ÿ You can specify it when you use the GNNS manager to import from CORS.
P.s.?ÿ Welcome to the Beerleg/SurveyConnect
@john-putnam Hi John. Thanks for your answers. I have not find yet the solution to my issues related to Infinity. It is a fact that when importing raw data from a reference station throught the web I could manage the interval rate, but in the case I have some files on my PC HD from campaigns and, for instance, I would want to reduce the size for the project database from 1 s obsewrvatoin files to 30 s, I can not find the way to do it. Whith the former Leica postprocessing s/w , Leica Geo Office, that was a very simple task, but with Infinity it is an "impossible mission". Another issue it is that related with editing the header for exporting to RINEX. As you say on the s/w help about these topic I could not find an explanation. I think I should try to contact with Leica Tech Support.
Best regards, Ernesto
