OPUS
c-man
(@c-man)
When uploading my dual-frequency GPS observation (data file) at the OPUS website?ÿI get the following Software error:
Month '-1' out of range 0..11 at /home/Lib_GPS/lib/RINEX/Parse.pm line 205
What could be wrong with my rinex file?
Posted : July 12, 2019 9:17 pm
Can you open your Rinex file with an editor and post here the header and first few lines of data? That would allow a much better guess as to the problem.
Posted : July 12, 2019 9:36 pm
larry-scott
(@larry-scott)
I got the same thing!!!
Collected yesterday PM, submitted 2 hrs ago.
6012 OPUS-RS is not able to findsolution for your data set.
6012 OPUS-RS has stopped with the following message(s) in RSGPS
6012 network solution:
STOP(rdrnx): error reading rinex file: /var/tmp/opus_local/RS75/19193/pool/pass1930.19o
Posted : July 13, 2019 11:38 am
larry-scott
(@larry-scott)
I had the same rdrnx error on station York. So I excluded York. Then the error was paco.
Then rdrnx error on station pass.
So itƒ??s appears to be an opus problem.
Posted : July 13, 2019 11:41 am
larry-scott
(@larry-scott)
I submitted 2 rinex files, one right the other. One from 10 Jul and one from 12 Jul. The 10 Jul returned just fine. The rdrnx error doesnƒ??t indicate that my file is unreadable.
Posted : July 13, 2019 11:53 am
larry-scott
(@larry-scott)
I checked my rinex file. Nearly identical to another to a file from 2 dayƒ??s earlier.
have you ever seen Rdrnx errors indicating the process stopped on the cors file, not the user file?
Posted : July 13, 2019 12:04 pm
larry-scott
(@larry-scott)
@bill93
Here is my file. Looks pretty normal. I'd appreciate it if you see anything glaring. I checked the ecef coord and it's accruate. the successful file from just 2 prior only a mile away, returned 9 cors sites used. I was surprised the error read stopped on the first cors file.?ÿ
Posted : July 13, 2019 12:15 pm
I just submitted a session and note that the bar graph shows that about 48 out of 76 (estimated) OPUS-RS runs today are in the red meaning failed. OPUS-S looks good.
Posted : July 13, 2019 1:05 pm
I don't know if it is significant, but it looks pretty strange to see your header line with 13 leap seconds. I think we're at 18.
Posted : July 13, 2019 1:12 pm
OPUS-RS gives me essentially the same error o Larry's file with either 13 or 18 leap seconds.
6012 OPUS-RS is not able to find a solution for your data set.
STOP(rdrnx): error reading rinex file: /var/tmp/opus_local/RS55/19193/pool/york1930.19o
Posted : July 13, 2019 1:20 pm
larry-scott
(@larry-scott)
I saw the red/green. Didnƒ??t know it means
Posted : July 13, 2019 2:08 pm
c-man
(@c-man)
Here they are @bill93
3.03 OBSERVATION DATA Mixed(MIXED) RINEX VERSION / TYPE
cnvtToRINEX 3.09.11 convertToRINEX OPR 30-May-19 14:57 UTC PGM / RUN BY / DATE
----------------------------------------------------------- COMMENT
ga0240 MARKER NAME
ga0240 MARKER NUMBER
GEODETIC MARKER TYPE
GNSS Observer Trimble OBSERVER / AGENCY
5841F00268 R10-2 5.40 REC # / TYPE / VERS
TRMR10-2 NONE ANT # / TYPE
692671.8376 -5078963.7976 3783550.6304 APPROX POSITION XYZ
2.0500 0.0000 0.0000 ANTENNA: DELTA H/E/N
R 6 C1C C2C C2P L1C L2C L2P SYS / # / OBS TYPES
G 6 C1C C2W C2X L1C L2W L2X SYS / # / OBS TYPES
15.000 INTERVAL
2019 5 28 15 23 30.0000000 GPS TIME OF FIRST OBS
2019 5 28 15 53 45.0000000 GPS TIME OF LAST OBS
0 RCV CLOCK OFFS APPL
9 R06 -4 R07 5 R14 -7 R15 0 R16 -1 R17 4 R18 -3 R19 3 GLONASS SLOT / FRQ #
R24 2 GLONASS SLOT / FRQ #
R L2C -0.25000 SYS / PHASE SHIFT
R L2P 0.00000 SYS / PHASE SHIFT
G L2X -0.25000 SYS / PHASE SHIFT
18 LEAP SECONDS
18 # OF SATELLITES
G01 115 111 115 113 109 115 PRN / # OF OBS
G07 122 122 122 122 122 122 PRN / # OF OBS
G08 122 122 122 122 122 122 PRN / # OF OBS
G09 122 122 122 122 122 122 PRN / # OF OBS
G11 122 122 0 122 122 0 PRN / # OF OBS
G16 41 41 0 40 40 0 PRN / # OF OBS
G23 82 82 0 82 82 0 PRN / # OF OBS
G27 122 122 122 122 122 122 PRN / # OF OBS
G28 122 122 0 122 122 0 PRN / # OF OBS
G30 122 122 122 122 122 122 PRN / # OF OBS
R06 111 0 0 111 0 0 PRN / # OF OBS
R14 61 61 61 61 61 61 PRN / # OF OBS
R15 122 122 122 122 122 122 PRN / # OF OBS
R16 122 122 122 122 122 122 PRN / # OF OBS
R17 122 122 122 122 122 122 PRN / # OF OBS
R18 122 122 122 122 122 122 PRN / # OF OBS
R19 32 32 32 32 32 32 PRN / # OF OBS
R24 45 32 44 45 32 44 PRN / # OF OBS
DBHZ SIGNAL STRENGTH UNIT
END OF HEADER
> 2 1
*** Start of Kinematic Data *** COMMENT
Posted : July 13, 2019 4:14 pm
larry-scott
(@larry-scott)
8 AM today, 14-Jul, I re-sent the gps data to opus and it returned just fine.
So, it probably was a temporary thing. You should try sending your original file again.
And the rapid static fail rate this morning was 25%. There might be a batch of corrupt files.
Posted : July 14, 2019 6:50 am
MarkSilver
(@mark-silver)
Can I tell my OPUS Error Message joke again, or is it totally worn out?
???Ÿ
Posted : July 14, 2019 9:30 am
@mark-silver
This one?
https://surveyorconnect.com/community/gnss-geodesy/opus-error-message-433273/paged/3/#post-434466
Posted : July 14, 2019 9:50 am
MarkSilver
(@mark-silver)
???œ
Posted : July 15, 2019 7:55 am
