NGS Geoid Calculato...
NGS Geoid Calculator
 ease
(@ease)
When using this tool to convert from ellipsoid height to geoid height:
https://www.ngs.noaa.gov/cgi-bin/GEOID_STUFF/geoid12_prompt1.prl
The data returned is simply a negative number, which I'm assuming is the amount of meters the ellipsoid is below the GEOID? This would agree with the topo maps I have in the area, but why make the results so arcane? I understand it's the gov, but still.
Posted : April 16, 2014 12:30 pm
Actually...The 'N' Value is the "distance" (in meters) FROM the Ellipsoidal Surface TO the Geoidal Surface. So a negative 'N' value, tells you that the Geoid is BELOW the Ellipsoid (Ortho Height GREATER than Ellipsoid Height).
Posted : April 16, 2014 12:37 pm
(@jered-mcgrath-pls)
> Loyal
:good:
Posted : April 16, 2014 12:48 pm
(@cliff-mugnier)
That's because there's a lump on the other side of the planet that causes such an anomaly of gravity ... called the Himalayas.
Posted : April 16, 2014 1:11 pm
 ease
(@ease)
Ahh thank you.
Posted : April 16, 2014 4:59 pm
