when I downloaded msol182.zip instead of mosl182.zip from ufcors, things improved dramatically..... :whistle:
Rankin_File, post: 327190, member: 101 wrote: when I downloaded msol182.zip instead of mosl182.zip from ufcors, things improved dramatically..... :whistle:
I know the feeling. I spent close to an hour the other day trying to figure out why my RTK radio wasn't reaching the rover more than 150 out. Turns out you really do need to screw on that little antenna!
Alan Chyko, post: 327191, member: 1145 wrote: I spent close to an hour the other day trying to figure out why my RTK radio wasn't reaching the rover more than 150 out. Turns out you really do need to screw on that little antenna!
Been there. Done that. It really does work better, when the wire is hooked up!
Alan Chyko, post: 327191, member: 1145 wrote: I know the feeling. I spent close to an hour the other day trying to figure out why my RTK radio wasn't reaching the rover more than 150 out. Turns out you really do need to screw on that little antenna!
In the early days the radio would fry if you turned it on without the antenna attached. Very expensive lesson...
thebionicman, post: 327199, member: 8136 wrote: In the early days the radio would fry if you turned it on without the antenna attached. Very expensive lesson...
This was the rover antenna, fortunately.
The dang WVSH keeps getting downloaded instead of WYSH, I actually think it's a problem with CORS,,,,,,B-)
I had to read that several times over before I got it.
