Leica Viva GS15 fir...
Leica Viva GS15 firmware upgrade problem
1 Users
MarchiondaSurvey
(@marchiondasurvey)
I have GS15 and CS15. Both are past the end of maintenance date. The end of maintenance date was later than needed for the newest firmware update. The CS15 took the firmware update perfectly fine. Gs15, not so much. What I found out after the fact was that the GS15 end of maintenance date on the actual receiver is much earlier that what is listed on leica MyWorld. I have a license key listed in myworld that matches the date of the cs15. I need to somehow tell the gs15 that the end of maintenance date is different than what is physically on the gs15. A possible important note is that I can only update from the cs15 with Bluetooth. I do not have a cable to hook it up to the PC. Any advice or thoughts are appreciated.
Thanks
Karl
Posted : March 28, 2016 5:33 pm
MarchiondaSurvey
(@marchiondasurvey)
I figured it out. Typed in the key manually. Thought I had tried it before, but it was the wrong key. All set, nothing to see here.
Posted : March 28, 2016 7:12 pm
