I have one problem with my gps RX900 bluetooth in my controller doesn't work!
When i go to Start - Control Panel - Bluetooth Device Properties (and i press Scan Device was shown this message "Bluetooth hardware error 10050 (controller not present)"
Dose any one can help me what should i do?
My Controller is Leica: RX900, Art. No.: 748414
Ennkis,
I would not worry with the Windows CE side. Try to do everything inside SmartWorx on the RX900. The BT paring information is kept inside SmartWorx and also in Windows CE so maybe you just need to reset the pairing information to get it to work.
Try this first... this process will clear the BT pairing in SmartWorx and will see if the RX900 can find the ATX900 with BT.
1. Main menu - go to 5 Config - then choose Instr. Config...
2. Next choose Antenna
3. Highlight the Antenna: field and select the red key in order to display the antenna listing'
4. You need to delete the antenna definition you usually have selected while using the gear. For example if you always select ATX900 POLE then this is the one you need to delete.
5. Highlight the antenna definition you have been using and select F4 (DEL). Answer F6 (YES) when ask if you really want to delete it.
6. Now this antenna definition is deleted and the BT paring information is also gone.
7. Now select the key and then select F5 (DEFLT) which will bring back all antenna definitions at their factory default settings
8. Highlight the needed antenna indention and then select F1 (CONT)
9. No with the proper antenna definition selected in the Antenna: field make sure in the Comm: field that Bluetooth is selected. The ID Address field should be blank since the BT pairing ID was just deleted.
10 Select the F4 (SRCH)to begin searching for the BT connection with the antenna. Make sure the antenna is turned on.
Remember that the BT transmitter on the RX900 is in the upper left corner of the housing and on the antenna the BT transmitter is on the bottom of the antenna. Make sure you have a foot of space between the antenna and RX.
Let me know if you still get an error or if it does not work.
The BT pairing password code that you need to enter is four zeros BT PW = 0000
The GPS900 is a very good unit. The trick with the Bluetooth is to understand proper sequencing when setting up. Make sure your base and rover receiver are clearly identified.
When setting up the base, once the last step completed, the Bluetooth automatically kicks off as it expects the next logical step: connection with the rover. Then power up the rover receiver and the Bluetooth connects.
I really like the 900 even if it had bad press.
Thank you for this Solution but again this steps dose not working i remove from the list all of antenna and set as default because not solved.
Do you have any suggestion to me what should i do?
