Javad-LS - Consider...
Javad-LS - Considering another rover addition to the family
10 Users
stlsurveyor
(@stlsurveyor)
Great Pics!
N10,000, E7,000, Z100.00
PLS - IL, MO, AR, KS, MN, KY
Posted : October 15, 2016 1:28 pm
Nate The Surveyor, post: 395369, member: 291 wrote: "Nobody does it better...."
...makes me feel bad for the rest.
Posted : October 15, 2016 8:18 pm
johnhls
(@johnhls)
Thanks guys, that is the reason I am thinking of this for myself. My crew is using the latest greatest Leica gear and I have been using the legacy gps receivers when needed. I liked the compact nature of the LS setup and I am usually going out into typical canopy for our area to recon or verify existing control.
I have always thrown out the vertical in canopy shots, so was just curious how close the LS vert in a fixed solution was.
Adam, so it is a simple computer conversion routine to export LS points and import into Carlson?
One other question I have is the LS use of sim cards for RTN setup. We are plugged in to our local provider's network and I would want to continue to use it with the LS. Is this a simple hardware/software setup?
Thank you,
John
Posted : October 17, 2016 6:58 am
adam
 adam
(@adam)
johnhls, post: 395543, member: 3240 wrote: Thanks guys, that is the reason I am thinking of this for myself. My crew is using the latest greatest Leica gear and I have been using the legacy gps receivers when needed. I liked the compact nature of the LS setup and I am usually going out into typical canopy for our area to recon or verify existing control.
Thank you,
John
The LS will export what Carlson needs, no conversion is needed. The LS can have an internal GSM modem installed for use with a sim card. If you use Verizon as your carrier then you will need a mifi device or your phone as a hotspot.
Posted : October 17, 2016 7:41 am
johnhls
(@johnhls)
Thank you.
Posted : October 17, 2016 8:46 am
jmh4825
(@jmh4825)
I am fairly new to GPS and have never used a javad. I don't understand how this receiver can get a fixed signal in canopy like the pics show?
Posted : October 17, 2016 7:06 pm
Well, I am a long time RTK user. My old RTK is a Topcon Legacy E. It could not work in those places. Nope. Waste of time.
Without the details, Javad is:
Tracking MORE channels, than anybody.
Analyzing more bad data, than anybody.
And coming up with the right answer, in impossible places.
That's your short answer.
Nate
Posted : October 17, 2016 7:36 pm
John Evers
(@john-evers)
JMH4825, post: 395657, member: 10876 wrote: I am fairly new to GPS and have never used a javad. I don't understand how this receiver can get a fixed signal in canopy like the pics show?
JMH,
I can assure you that the LS can obtain great results in the canopy which I have seen the users post photos of. Not just a RTK position solution, but a comparative static solution as well.
It is really something that you need to see in person. There are some good surveyors that would be glad to help. You can find a list of these people on the Javad website under support.
Posted : October 17, 2016 7:43 pm
jmh4825
(@jmh4825)
That's pretty impressive. Not trying to be skeptical just trying to understand how. Thanks for the input.
Posted : October 18, 2016 4:18 am
adam
 adam
(@adam)
JMH4825, post: 395689, member: 10876 wrote: That's pretty impressive. Not trying to be skeptical just trying to understand how. Thanks for the input.
JMH, I would be glad to meet up with you sometime and show you the equipment. From your picture you are somewhere in the mountains, I work in the mountains and foothills of NC.
Posted : October 18, 2016 5:35 am
