BRX7 Base Rover Ext...
BRX7 Base Rover External Radio settings
JLSherm82
(@jlsherm82)
Its been a long day so ill try to keep it short
Equipment:
Carlson BRX7 Base/Rover (RTK) w/ GPS, Glonass, Beidou, Galileo.. Had it less than a week
Carlson Surveyor2 w/ SurvCE 6.12
Satel Satelline TA18 EasyPro 35W
Our "customer service" at L-S says a have to have my radio configured to be a radio (NOT a repeater) and must be connected via cable @ my base. Then if I need more range I can have ANOTHER radio as a repeater. Ive always used internal at the base and then set my repeater a little bit in range if i needed help getting corrections to my rover. Regardless.. I cant seem to make this work. If i do have to use a radio at my base, what are my settings for optimum range in canopy? And then are there different settings for say.. trying to get all the range i can on a long stretch (17 miles) of highway cross sections? No network, no opus, RTK only.. I have plenty of experience with GPS and i havent tried everything i can, i ran out of daylight so now im hoping some of you smart fellas can give me something to start with in the morning. (Besides a headache) if you ask me, customer service is just trying to sell my boss a few more Satel radios.. But i dont write the checks and im not the boss.. Just the guy trying to figure it out. Thanks for the help in advance!
Posted : November 9, 2021 8:53 pm
ladd-nelson
(@ladd-nelson)
While not written specifically for the Carlson BRx7, see if the communication settings information in Carlson Knowledgebase article #1076 gets you closer to your goal. If not, Carlson Technical Support might have other ideas. I hope this information helps.
Posted : November 11, 2021 7:55 am
MarkSilver
(@mark-silver)
While not written for the Satel repeater, this document:
?ÿ https://iggps.com/out/iGR/faq/iGRwithBRx7_R003.pdf
does work with the BRx7 (I wrote the FAQ and personally tested it so I know it works.) Something in it may help you with the Satel radio.
Good luck! This radio stuff if complicated.
Posted : November 12, 2021 1:10 pm
Posted by: @mark-silver
Word
Posted : November 12, 2021 2:05 pm
