Star*Net question--Norman Oklahoma
yswami
(@yswami)
Aloha, @Norman:
First...I would like to thank you again for your guidance and help with raw data processing.
I was retracing the your steps by importing the raw data again.
1. It failed just like you said but showed the line numbers with trouble. I fixed it by looking other valid data.
2. Data was imported fine there after. Then I changed the point #1 to partially fixed as you did. Good so far...
3. Here is something different than yours...
Your file has one DV and 3 M lines. For some reason I have one DV and 4 M lines. I noticed the fourth M line is mean of all three sets that created by the field software. Star*Net is utilizing this lines as well.
Question: Did you remove them manually? Or what happened in your case when you were processing the raw data?
Thank you so much!
Posted : June 18, 2015 3:25 pm
Norman_Oklahoma
yswami, post: 323062, member: 7679 wrote: ....
Yes I did. The data in that 4th line is the first 3 lines averaged. It happens when you use the "Traverse" function in the dc to advance your setup station. A bug in the converter.
Leaving it in wouldn't make the adjustment error out, but it would cause the the data to be weighted improperly. And, depending on the order you collect data in, it can have improper measure ups on it. Which will bust your adjustment.
Posted : June 18, 2015 3:43 pm
yswami
(@yswami)
Aloha, Norman:
Thanks for the confirmation!
Btw, you have two profiles that is running simultaneously 🙂
Posted : June 18, 2015 3:46 pm
Norman_Oklahoma
yswami, post: 323070, member: 7679 wrote: Btw, you have two profiles that is running simultaneously 🙂
As long as I don't answer my own questions it should be alright. One is home, one is work. The changeover kind of impressed it on me.
Posted : June 18, 2015 4:25 pm
yswami
(@yswami)
Norman Oklahoma, post: 323080, member: 9981 wrote: As long as I don't answer my own questions it should be alright.
Hahaha...
Posted : June 18, 2015 5:25 pm
yswami, post: 323094, member: 7679 wrote: Hahaha...
Y that was your 777th message. Cool.
Mahalo.
Posted : June 18, 2015 5:50 pm
yswami
(@yswami)
Aloha, Brad:
Didn't pay attention to number. Thank you for pointing it out. An I noticed it was exactly 2 years yesterday since I signed up on this forum. Man...I came long ways! Never dreamt of working with LSA etc. when I signed up then! Thank you to each one of you for helping me to get here.
Posted : June 18, 2015 6:44 pm
