RL wavelength spectrum
8 Users
Wondering out loud here about the use of RL distances on dark red brick. Shots well within operating range of instrument.
There are other factors involved in RL shots, but I was hoping to learn some about the physics (if it applies) of light spectrums
and affects on RL distancing.?ÿ Thank you
Posted : November 15, 2020 2:40 pm
not-my-real-name
(@not-my-real-name)
RL?
Posted : November 15, 2020 5:27 pm
geeoddmike
(@geeoddmike)
Reflectorless?
Posted : November 15, 2020 5:35 pm
stephen-ward
(@stephen-ward)
Maybe RL=Red Laser.
Posted : November 15, 2020 6:15 pm
not-my-real-name
(@not-my-real-name)
Maybe it's Ralph Lauren. Anyway, this is a good example of why non-standard abbreviations do not work.
Posted : November 15, 2020 7:33 pm
stephen-ward
(@stephen-ward)
I've used Topcon, Leica, & Trimble.....one of them uses RL in their documentation.?ÿ I just can't remember which one at the moment and lack the time to go look.
Posted : November 15, 2020 9:54 pm
Leica uses RL and Topcon uses N/P for reflectorless
Posted : November 16, 2020 8:30 am
rover83
(@rover83)
The reflectivity of brick is pretty low to begin with. Found this site which has approximations of reflectivity of common building materials.
As you mentioned, there are other factors as well.?ÿIn my experience, the most critical factor is angle of incidence. No matter how reflective that object is, if most of that beam isn't going back to the instrument it won't get a good return.
Posted : November 16, 2020 9:40 am
Posted by: @rover83
While the reflectivity of brick may be lower than many other materials, a rough surface means that it will spread that reflection out in more directions, so angle of incidence will be less critical than for a smooth surface.
Posted : November 16, 2020 9:47 am
stephen-ward
(@stephen-ward)
@bill93 that may be true, but I can tell you from experience that shooting brick house corners at 30+ degrees off angle with a Trimble S6 does not give reliable results.
Posted : November 16, 2020 3:39 pm
@rover83 Thank you, Sir.
Posted : November 16, 2020 4:28 pm
I was able to shoot two sides of a 4'x4' brick column from two separate traverse points, and the results are within 0.01' of what the 25' tape reads.
I think my head got lost in wondering if it were that an object that appears red, to our eyesight, is absorbing all the remaining wavelengths?ÿ
in the light spectrum, and reflecting only the red, or if it were absorbing the red .. or ?????ÿ no clue here.
There's been documentation that certain surfaces or colors don't return good RL results.?ÿ Thanks registereds.
Posted : November 16, 2020 4:41 pm
hpalmer
(@hpalmer)
I have a study Charlie Glover and Geometrics performed from (portion) high atop our building that centered on Leica's laser, its reflectivity, and what happens when it reflects off a corner.?ÿ I will see if I can find it and if it not proprietary, will upload same.?ÿ If I cannot find it, maybe Doug (if he is reading) or someone else can and will.
Posted : November 16, 2020 5:06 pm
rover83
(@rover83)
Depending on the type of instrument, as well as its age, certain EDMs will perform better than others.
Trimble used to have two options available for the S6, one using time-of-flight and the other using phase-shift. I believe the S7s are all TOF now...the signal processing has supposedly improved over the years as well, to the point where the TOF is pretty much neck-and-neck with phase shift, plus has the benefit of longer range.
I seem to remember reading a paper discussing Leica's EDM and ATR capabilities that indicated Leica uses some combination of phase analysis and TOF to get results. No idea how they do that...but Leica still seems to have an edge over Trimble in the reflectorless department.
Posted : November 16, 2020 5:54 pm
