Truck gearing quest...
Truck gearing question
14 Users
(@mathteacher)
My son has a 2018 Chevy Silverado with the 5.3 V8 and six speed automatic transmission. He's unhappy with its performance, says it's sick. Now he was an 82nd Airborne paratrooper used to hitting the ground maybe 20 seconds after jumping from 700 feet, so his idea of performance is a lot different from mine.
Anyway, he wants to change the rear differential to 3.73 to 1 from 3.42 to 1. I think the acceleration improvement will be minimal and he'll turn more RPM in every gear and at every speed. He says that the six-speed is so high in top gear that the RPM difference will be minimal, and the acceleration difference will be significant.
So, who's right?
Posted : August 30, 2022 5:45 pm
(@olemanriver)
The 3.73 should get him off the line quicker. ?ÿAnd pull harder. ?ÿOn the top end he will rev more rpms higher. The 3.42 will be more sluggish off the line but allow for less rpms at higher speed.?ÿ
I have a 4.30 rear end in my truck i use for towing. Same truck with a 3.55 has less towing ability. Hope this helps. He has it backwards I think. But I donƒ??t know where the gears ratio is on the transmission either. That can make a difference.?ÿ
edit. He wants to move to a 3.73. ?ÿHe is correct I read it backwards lol. Now if he goes to changing tire size (height) he can either increase the final gear ratio or undo what he was trying to accomplish. 3.42 to 3.73 will change his mpg some and especially when the foot is heavy. Oh how I remember my youth days. ?ÿ1977 ford f150. Literally drug it out of a briar patch on an old farm. $100 worth of hornet and wasp spray I was finally able to get it into the barn. Removed the engine that was blown and built a 351w had heads pulled from a 67 ltd with big plugs. ?ÿStraight pipes to cherry bomb glass packs 8ƒ? echo tips headers low end mid range cam. Retarded timing I could set off car alarms in parking garages by snorting it as I drove by. Had all the body work done primer grey. Drove around on a 5 gallon bucket for first year as seat had been completely eating away by rats. ?ÿHelped my cousin re do another seat he did upholstery. Had new headliner put in. But by the time I had the money saved up and all mechanical and body work done I was on my own financially and real world budgets had to take priorities. ?ÿSold the truck to a man who had lost his son from a log truck crash and he was helping his grandson find his first ride. I told him if he removed the engine and sell it to a guy who drag raced he could have the truck. I didnƒ??t want someone on my mind dying in a fast truck. It would top out at over a 100 mph. I had dome pistons and other goodies under the hood. When that 4bl carb opened up and she would get gone. She was way to fast and quick. The day I sold it my dad said my momƒ??s prayers had been answered. She knew I was going to kill myself acting a fool. ?ÿNow I drive around like a snail. ?ÿ
Posted : August 30, 2022 6:13 pm
(@michigan-left)
@mathteacher
If you're talking to your son about his feelings, and asking us about who's right, then I don't know if anyone can help you.
Have him get a manual transmission for the truck, and then the only way it will feel sick is every time he has to buy new tires for it.
Posted : August 30, 2022 6:16 pm
(@half-bubble)
Anything less than a 4.10 is a car not a truck. The chariot has 4.56 and the wood truck has a 6.17 posi.
Posted : August 30, 2022 6:20 pm
(@stephen-ward)
If I found the correct specs and did the math right, he'd be turning about 150 more rpm at 70mph in 6th gear.
All of the stock wheel and tire combinations I could find for a 2018 ranged from 99.5" to 101" circumference so I went with 100" circumference for easy math.?ÿ The 6th gear ratio for the 6L80 transmission is 0.67:1.?ÿ Someone else will have to comment as to the perceived acceleration difference off the line.?ÿ
Posted : August 30, 2022 6:27 pm
(@stephen-ward)
post 124475 0 81402600 1382619305
Here's the table I found for the gear ratios in the transmission that I believe that truck came with.
Posted : August 30, 2022 6:30 pm
(@jon-collins)
The kid is right. That little bit of a change will help it scoot a bit. Not a ton, not enough to warrant the cost and effort but it will. The higher rpm at highway speed will be negligible in terms of mpg.
I went the opposite in my personal truck. Stock 3.73s then I went to a 35in tire effectively taking me to that 3.42 range. Hurts my towing and acceleration, but a fair trade off to me to roll on 35s. Should go to a 4.56 for awesome towing on the 35s but the expense is not worth it.
Posted : August 30, 2022 7:39 pm
Posted by: @mathteacher
Depending on his age, that might mean it's great.
Posted : August 30, 2022 7:44 pm
(@jflamm)
Some new computer calibrations might be needed with a gearing switch.
Posted : August 31, 2022 3:30 am
If it's a two wheel drive it should work fine to give slightly more power at take off (3.45 to 3.73 isn't much of a change).
I like the lower gears when I want to go slow, when I'm in 4 low range I want it to go walking speed and retard it going down steep hills.?ÿ
However, if it's a 4x4 truck a lot more will have to happen than switching out the rear end. Might as well trade it in at that point.?ÿ
Posted : August 31, 2022 4:19 am
(@mathteacher)
@mightymoe?ÿ
It's a 4wd. What are the considerations there?
Posted : August 31, 2022 5:06 am
(@jon-collins)
@mathteacher he will have to change the front diff gears as well. Again not worth the cost. I'd say about 1g per diff.
Posted : August 31, 2022 5:33 am
@mathteacher?ÿ
What Jon said, it would be a major undertaking and unless you have a really good mechanic that does this often, I'd avoid it.?ÿ
Posted : August 31, 2022 5:55 am
(@mathteacher)
@jim-frame?ÿ
You've got to remember that I'm older than dirt. My twin sons are 50. The ex-paratrooper has slowed down some, but he still likes machines that kick a little.
Posted : August 31, 2022 6:01 am
But officer my gauge said I was only doing 54MPH.?ÿ?ÿ
Posted : August 31, 2022 6:33 am
@jim-frame?ÿ
I hate how slang keeps using the opposite meanings for words.
Posted : August 31, 2022 7:08 am
(@350rocketmike)
My truck could really use this upgrade (it has 3.42 gears with a 4 speed auto). I don't really ever use 4th gear as it's always downshifting on every little hill with all the gear in the back.?ÿ
Posted : September 1, 2022 2:43 am
(@olemanriver)
@mightymoe so true. If it is a 4wd then he will need to get front done as well. Or he will have all sorts of issues when locked in. He should find himself a 4.10 or taller gear if he wants to get her going quicker off the line. Throw in a new cam and let her breath a bit with some headers etc. oh i miss my youth when all I had to worry about was spending money on my truck and some gal. ?ÿLol. Now I am worried about kids college and bills and cows etc.
Posted : September 1, 2022 5:58 am
(@john-nolton)
Math Teacher There are a lot of things your son can do. Its all about money = power. Look at Gale Banks web site and on YouTube.
Gale Banks holds the land speed record for a diesel truck; 220+ mph and gets 20 m/gal. Its only money.
Posted : September 1, 2022 7:24 am
(@ncsudirtman)
yukon gear or GM Performance Products is the ring & pinion I'd go with - if it's 4WD he'll need to regear the entire truck. Did this with 4.10 ratio on a 2012 GM 1500 when the tires were swapped to some heavier 38's and a 12" lift. Gears will help with around town commute (stoplight to stoplight) and towing but the highway mileage will decrease and he'll be turning higher RPM's. He will also need to retune the ECM (not existing concrete monument either) - I think Black Bear Performance is who I used as they specialize in GM gas pickups and SUV's. If he's doing the regear then I'd strongly encourage a cold air intake and a full exhaust (long tube headers with adequate exhaust and NOT shorty headers as they're a waste of time & money). They should at least offset the fuel economy loss and give him the seat of the pants feel he wants.
He needs to understand - once you start tinkering with it for better performance the bug never really stops. Either leave the vehicle stock or be prepared to sink plenty into a truck that he'll never get back out of it. I've heard the newer GM motors do really well with boost (either a supercharger or turbo) but I have gotten out of performance related things as the kids enjoy my fun money now. Tell him to stay away from diesel pickups or be ready to spend 3x what it costs to to modify a gas pickup - everything will tear up eventually with the increased power
Posted : September 1, 2022 8:23 am
