Ethics Question - Hiring RPLS to Sign Reports
16 Users
(@geojmitch)
Active Member Registered
Hello all,
I'm hoping to receive some input from all of you experienced surveyors out there.?ÿ My background is in geophysics/geology, but have worked as an independent contractor for licensed land surveyors providing ground control points for lidar/photogrammetry.
I am branching out and starting my own consulting operation in Colorado.?ÿ I want to offer survey-grade geophysical mapping and drone services including GCPs, etc. (<2cm). I am not licensed and have no easy path that I'm aware of to become licensed, however I intend to hire a RPLS in time.?ÿ?ÿ
I have worked quite extensively on large-scale Federal projects with strict survey-grade deliverables (sub-centimeter) and am quite capable of performing the simple survey-related services mentioned above. I am considering the option of hiring a RPLS as needed to review my work and sign any necessary reports.
I'm using the Trimble ecosystem - TBC, Access, UASmaster, RTK Networks
Is this a bad idea??ÿ Or something that RPLS would even consider??ÿ
If this isn't such a bad idea, what would an acceptable payment rate be for such an arrangement?
Thank you for reading my post and I look forward to reading your responses!
Posted : 30/12/2020 8:47 am
Famed Member Customer
In Idaho you could be charged with unlicensed practice, and the surveyor with aiding and abetting. You could contract with a surveyor to do the control work with no issue.
Keep in mind that's Idaho ymmv...
Posted : 30/12/2020 10:59 am
(@flyin-solo)
Noble Member Registered
hahaha, well, if you need a guy who won't ask many questions (strangely, as he's way active in raising hell with various state boards) and who'll stamp just about any piece of paper you put in front of him, lemme know.?ÿ i know of a guy in the denver area who fits the bill.
Posted : 30/12/2020 11:09 am
(@lurker)
Prominent Member Registered
Even a 10' pole won't help
Posted : 30/12/2020 12:03 pm
(@stlsurveyor)
Famed Member Registered
I'm licensed in CO and the company I work for has an office in Denver. You can just sub the work to me? Or just have a local surveyor near your projects do it. Only real option is to hire a PLS full time of just sub it out.?ÿ
Posted : 30/12/2020 12:16 pm
(@rover83)
I'm pretty sure that CO specifically includes geodetic surveying and engineering control in the definition of the practice of land surveying, which likely includes GCPs for aerial mapping and any other control work. If you aren't starting out with a licensed surveyor, you're likely opening yourself to problems with the board.
Posted by: @geojmitch
I wouldn't say that sub-centimeter deliverables are "simple survey-related services". Especially if they are derived from remote sensing methods, or mixed observation methods of variable quality. Which is why a license is required to oversee that type of work.
And regarding oversight, your wording indicates that you are going to be in charge of projects, and effectively using the PLS as a subcontractor, just for review purposes. That's likely going to be a problem, as many (possibly including the board) would interpret this as a "rubber-stamp" position.
If I were to join a consulting venture as the one you are describing, there would be stringent requirements about control of projects and "veto" power over particular things. You will have to let the one whose license is on the line make final decisions about particular aspects of the project.
It can be done, but it's going to take full cooperation between you and the license, as well as probably a full-time position for the license. I don't think you're going to attract top talent otherwise.
Posted : 30/12/2020 12:48 pm
(@mike-marks)
I'm curious.?ÿ What exactly is geophysical mapping services??ÿ And what does "have worked as an independent contractor for licensed land surveyors providing ground control points for lidar/photogrammetry"?ÿmean?
My initial suspicion is you provide the contract field crews to set ground control for your services under the supervision of an LS who certifies the control for photogrammetric/lidar mapping projects.?ÿ No big deal; I've hired contract field crews when overloaded with work and been on the other side of the road where my crew gets hired by a competitor for a few days if they're in a crunch.?ÿ But there's a clear line here; an LS has to be in charge if your nascent firm is offering locating physical features for most purposes.?ÿ Contracting an LS to fill that role is an acceptable avenue but competent LSs?ÿ are kinda finicky and will want supervisory control of your crew(s) & mapping and charge accordingly. Or you can shop and contract an LS who will show up twice a month to stamp & sign your work without review for a few hundred bucks per map.?ÿ They're out there.
Congrats on sub 2cm accuracy which I believe any competent user of GPS equipment can achieve in optimal conditions (not vertically) locally but it's when it hits the fan, bad control problems, new localization every day, etc., that number can go horribly wrong, off by feet.?ÿ An LS can keep you out of trouble if he/she's monitoring things but carry on, contract an LS to sign off cheap on your work and you could go for years before the OMG mistake bankrupts you.
Posted : 30/12/2020 1:29 pm
(@rich-roberge)
Estimable Member Registered
"...and am quite capable of performing the simple survey-related services mentioned above."
What could possibly go wrong?
Posted : 30/12/2020 3:59 pm
Find an LS who wishes to make more money by using you as his sub for such projects.?ÿ The risk falls squarely on his shoulders in such a relationship.?ÿ But, he determines the fee structure and who gets paid for doing what.
Doing anything without an LS in total control will get you in big trouble with the State Board in every State I can think of.
Posted : 30/12/2020 4:05 pm
It's apparently an open market for "license leasing".?ÿ ?ÿEvery since word got out I had slowed down and sold out I've been approached regularly with offers that vary from 'almost legit' to 'shadily lucrative' to 'downright criminal'.?ÿ ?ÿ
I remember one 'firm' that boasted about the size of their organization and all the work they performed across the country.?ÿ None of their correspondence mentioned a physical address.?ÿ I wasn't surprised when I couldn't even find a website with their name.
But there are surveyors out there that will bite.?ÿ It shouldn't be too hard to find a "simple surveyor" to stamp "simple survey-related services".
Just my simple opinion you understand.
Posted : 30/12/2020 4:19 pm
@paden-cash
A local lady passed away three days ago.?ÿ Today would have been her 100th birthday.?ÿ Her youngest child was a classmate of mine back when we rode dinosaurs to school.?ÿ Between her obituary information and a little online searching I discovered my former classmate is now in Stillwater because her husband's architectural firm had decided to expand from their longtime home office in Wyoming.?ÿ How about that??ÿ Oklahoma is a dream spot for retirement age architects from Wyoming.
Posted : 30/12/2020 4:24 pm
Illustrious Member Registered
If you are just looking for a PLS to rubber stamp your work that is not likely to end well. Both of you will end up in the soup.
You could hire a PLS as an employee and engage in the surveying business without being licensed yourself (in many states). That PLS would not necessarily have to be engaged "full-time".?ÿ You would just have to be able to show that the PLS was the one making the actual surveying decisions. And when you are cutting the checks, that can be a high bar to clear.?ÿ ?ÿI recently left a job with an engineering company, owned by a PE, where I was the PLS in charge of the surveying end. That is a common situation.?ÿ?ÿ
Posted : 30/12/2020 4:34 pm
(@aliquot)
What does "background in geophysics" mean? If you have an advanced degree in geophysics you are just as capable as most surveyors are at figuring out?ÿ measuring with GPS/remote methods. There are places that strictly limit the requirment for licensure to boundaries, but unfortunately I don't think Colorado is one of them.?ÿ
Grouping boundaries and measuring/maping together under the same licence is archaic, but it won't be changing anytime soon.?ÿ
Posted : 30/12/2020 6:31 pm
(@stlsurveyor)
@aliquot
I think the rub occurs when the data is mapped, relied upon, and has real impacts and land right implications. For Geology and or Geophysics implications, such as here lies the gold, or here is karst rock you don't want to build on, or this ground is moving - well that is why the surveyor needs to be involved. I don't know sh!t about rocks but I can surely tell you where they are. So yes, boundaries and measuring are sometimes the same thing when they affect real property rights.?ÿ
Posted : 30/12/2020 6:38 pm
(@murphy)
Ethically, you should get licensed.?ÿ In all the states I've worked in, you would be surveying without a license.?ÿ I would only recommend hiring a rubber stamp if you aggressively pursue licensure.?ÿ
Take advantage of University of Maine's entirely online land surveying degree.?ÿ If you already have a B.S. you may find that you will only need a handful of classes.?ÿ
Your statement, "simple survey-related services", leads me to assume that you should not be providing any survey services.?ÿ Be open to the idea that you may be blissfully ignorant of the gaps in your knowledge (particularly propagation of uncertainty).?ÿ Conversely, you may know much more than all of us and we've just been over-complicating something that should be as simple as parking a GNSS receiver on a GCP and printing out a TBC accuracy report.
Posted : 31/12/2020 2:45 am
Page 1 / 3
Share:
