Capillary action in the spaces of any permeable material, such as soil, can cause water to move upward. The movement can be caused by the forces of adhesion, cohesion and surface tension. Water will flow up until the force of gravity is too much for it to overcome. Groundwater hydrology shows us that water will rise from what is called the phreatic zone or the aquifer below the ??water table? into the vadose zone by capillary action. Thereby making it unwise to say that water always flows downhill.
also true for walls and roofs, and then add a bit of wind and surprises happen
(we tore off the old and made a new garage roof last week, new kitchen roof next week, winter is coming)
Is the water really flowing up with Capillary action, or is it being pulled up?
Surface tension is definitely a property that comes with water, but, it is not unique to water. Intermolecular forces are what hold a liquid together. In water the forces are pretty high.
The forces at the surface are not the same as those that are surrounded by other molecules. The forces at the surface are drawn in toward the liquid causing it to rise. A effect that becomes more dramatic in the capillary.
Adhesion is a property of the soil. So you can have the water flowing upward by reason of it's interaction with the soil in part.
In business management it is common to find that $#it floats to the top.
Holy Cow, post: 456641, member: 50 wrote: In business management it is common to find that $#it floats to the top.
http://www.sewerhistory.org/miscellaneous/the-creation-author-unknown/
Well if we have to post normal stuff; adhesion is also the property that creates the miniscus in the vial level bubble. /normal stuff
There is other things going on also like salt contents. Plants use that to move water around, difference in salt content. The reason plants won't do well in salt water is because they can't set up salt content difference. Will die like a lack of water is going on. Then there is density. The Great Salt Lake has some causeways, railroads, built through it. Since most of the fresh water comes in on one side the salt content was reduced on one side of the causeway. They tried to even it out by placing some bridges to allow the water to pass. When they looked into it closely they found the water flowed one way on the bottom and the other way on the top, difference in water density. Basically water will move from high to low pressure. Like heat from hot to cold. That can be any direction, especially underground.
When in it up to your neck...
...keep your mouth shut
S#@t still flows downhill.
not my real name, post: 456611, member: 8199 wrote: Adhesion is a property of the soil. So you can have the water flowing upward by reason of it's interaction with the soil in part.
You can drape a towel over a tub with water and eventually the towel will become fully drenched and drain the tub.
