Does the TSC2 have a way to adjust screen contrast? I found where the TSCE did but haven't found it for the TSC2.
Should be the "Settings" under Windows, allows for brightness.?ÿ Never have seen a contrast function with the TSC2.
As far as I know the only thing you can do is hit the Fn button and the green on/off button to turn the light on and off. Frankly it basically is awful in certain light, I have to rotate the rod all the time to read the dang screen.
That's what I've been doing (rotating DC) just gets frustrating.
It seems to work better for younger surveyors, I guess my eyes that can't read the menu in a low light restaurant without my cheaters or my phone flashlight?ÿmaybe have something to do with it. ??ÿ
Although, I can see my phone just fine outside...??..
You may already know this but here goes:
Windows?ÿ >?ÿ Setting?ÿ >?ÿ System tab?ÿ >?ÿ Backlight?ÿ > Brightness
I think it defaults to lower power backlight on battery, I keep mine set to 100% on both battery and external.
That is the limit of my knowledge on the subject.
James
Thanks, I've got it set to 100%
