Can you import a dxf into Trimble Survey Controller 12.5 on a TSC2 Collector? I haven't had my TSC2 long, but haven't been able to figure it out, if you can. I downloaded a digital manual, but it doesn't give direction in it. It may not be for Version 12.5 either. It said a dxf is a "Map" file, but in the import options, I don't see any option to import a dxf or map file.
Thank you
It's been a long time since I used Survey Controller, but I am 90% sure that it takes and displays DXF files for selection, staking, etc.
The "import" routine is not needed/used for linked/map files. Just like newer versions of Trimble software, if the DXF resides in the same folder that the job does, it will be made available for display in the map.
Once the DXF is in place, it's usually accessed through the "layers" dialog, where you can turn the whole DXF or its individual layers on or off as needed.
Wasn??t that option somewhere under the LINKED FILES placed in the older versions?
