trimble to survce
2 Users
mattb
(@mattb)
Hi all
I have recently swapped from using trimble survey controller 12.5 to carlson survce. Instead of retyping out my entire codetable to put into survce, is there someway I can convert my trimble survey controller codetable to be read by survce?
Thanks
Posted : September 6, 2016 6:49 am
arctanx
(@arctanx-2-2-2)
If you can export your trimble dictionary to a .FXL file. You can then import your FXL file in Carlson's Survey Module. The command is EDITF2F -> CODE TABLE SETTINGS -> IMPORT TRIMBLE CODES
That's the method on the 2016 version. I haven't used it so I don't know if it works fully or if you'll need some additional tweaking.
Posted : September 6, 2016 9:11 am
mattb
(@mattb)
hi arctan
thanks for that. By Carlson's Survey Module, do you mean the desktop software? I don't have or use this. The only Carlson software I use is Survce on my data collector. Looks like I need some desktop software to do conversion?
Posted : September 6, 2016 5:10 pm
