Traverse Methods, and Software
mattcourage
(@mattcourage)
I currently use SCS900 software, but I'm considering a switch to Access. One of the issues with SCS900 is the traverse routine. I am not happy with it, and as a result I am still using Survey Pro to run my traverses. I then import the raw data into Carlson Survnet and do a least squares adjustment. I insist on doing least squares adjustments due to the fact that it doesn't limit how I make my observations. I can run a traverse between two GPS pairs, in any order, and then run sub-traverse lines, connecting lines, etc. without any issue.?ÿ
Does anyone have experience running a traverse in Access, and then doing a least squares adjustment in TBC? My local trimble tech said that Access does least squares traverse adjustment in the collector, but I doubt that. I did see that it does least squares averageing of observations to the same point, but I don't think it applies to traverse (Mean Turned Angle) observations. Also does Access allow you to export raw traverse data, so that I can bring it in to Survnet??ÿ
I appreciate any input, I am trying to decide whether or not to make the switch back to the "survey" side of trimble.
Also, since I am used to using the SCS900 design/workorder format, do you have to redo the station setup in access after switching to a new job?
Thanks!
Posted : March 20, 2018 6:42 am
Access absolutely allows you to export raw observation data. I have done it many times and made adjustments in StarNet. I'm sure that you would have no problem doing so with SurvNet.
Access and TBC are peas in a pod.?ÿ
BTW, you can export trimble format jxl files from your Survey Pro for import to TBC.?ÿ
Posted : March 20, 2018 7:19 am
sireath
(@sireath)
On my trimble I use the function measure rounds to measure multiple sets of angles and distance.?ÿ
I do not use onboard for any adjustments and download the raw data and process them in Starnet. I would think Carlson is able to read in Trimble files as well if not you can output as SDR33. I mainly use SDR33 as an output as it is a legacy thing (one where we understand the format and able to read the format) in my office, but you can use any raw data file format you are used too.?ÿ
Posted : March 20, 2018 6:31 pm
