Is there an efficient way to label static points in Topcon Tools? It's a frustrating experience the way I do it. First I have to go to the OCCUPATIONS screen to identify what the points are. If I put a note in the Occupation screen, it isn't carried over into the point screen. So then I have to flip back and forth from occupation screen to point screen and copy each decription, one at a time, into the point screen.
There must be an easier way.
If you are talking about the Point Name, double click on any field for that occupation. This will open the Properties window for that point. Go to the General tab and set the point name as desired.
I was referring to the point code. Wish I could label them in the Occupation window.
