With the TSC3 DC, after using VRS, on the map you would see a point for the base(s) used for correction. Is that information available with Topcon as well? If so, where do I find it?
Are you storing vectors, or just points? No idea how that specifically works in Topcon nowadays, but wonder if it could be a settings issue.
@rover83 I??ll have to check because I??d rather be storing vectors anyway because I believe I can use them as a check via post processing if something looks ??off? with the points. If any of that makes sense? Haha
after checking the configuration settings I couldn??t find anything about vectors, only maybe one setting called ??minimum SV? (if I can remember correctly)where I could enter a number. Perhaps that is what I??m looking for?
