Testing new GNSS Receiver Yesterday
21 Users
4+ hour static session on SW Corner of Wyoming
Sandstone obelisk set in 1873, USGS Disk set in 1899
Hard work, but somebody has to do it!
That's Mark Silver w/ the Banjo...
Posted : April 16, 2017 6:17 pm
dick emery
(@dick-emery)
Looks like it says $250 fine for disturbing it, which sounds like a lot of money for 1899.
Posted : April 16, 2017 6:37 pm
I don't think the banjo will disturb it...
Posted : April 16, 2017 6:49 pm
Loyal, post: 423808, member: 228 wrote: That's Mark Silver w/ the Banjo.
Taking lessons from TDD?
(for those who haven't been around long enough to remember him: TDD famously once said he could survey with a banjo if he didn't have other equipment.)
Joking aside, bluegrass or old-time clawhammer style?
Posted : April 16, 2017 6:54 pm
You would have to ask Mark 😎
I could however recognize most of the tunes though...
Posted : April 16, 2017 6:59 pm
Richard Imrie, post: 423809, member: 11256 wrote: Looks like it says $250 fine for disturbing it, which sounds like a lot of money for 1899.
Yeah, that number NEEDS to be updated to reflect 100+ years of inflation.
Posted : April 16, 2017 7:24 pm
Jon Collins
(@jon-collins)
Salt Lake datum
Posted : April 16, 2017 7:52 pm
Jon Collins, post: 423817, member: 11135 wrote: Salt Lake datum
Salt Lake Datum going Southwest, and Evanston Datum going Northeast from this Monument.
Posted : April 16, 2017 7:54 pm
OGBoundaryGuy
(@FRSH2O)
Looks like a nicer day than that morning you took me down there Loyal.
Didn't have a banjo player with us either;)
Posted : April 16, 2017 7:56 pm
sfreshwaters, post: 423820, member: 88 wrote: Looks like a nicer day than that morning you took me down there Loyal.
That's for sure.
It was a bit breezy there yesterday, but the Survey Oil didn't get warm :innocent:
Posted : April 16, 2017 8:11 pm
Joe the Surveyor
(@joe-the-surveyor)
7150 feet above sea level??!!..i'm lucky if I survey above 71.5 feet above MSL. Sometimes it's' 7.5' above MSL,
Posted : April 16, 2017 8:26 pm
Joe the Surveyor, post: 423823, member: 118 wrote: 7150 feet above sea level??!!..i'm lucky if I survey above 71.5 feet above MSL. Sometimes it's' 7.5' above MSL,
The next one on my "to do List" is about 30 miles South of Yesterday's observation.
1 National Geodetic Survey, Retrieval Date = APRIL 16, 2017
LO0172 ***********************************************************************
LO0172 DESIGNATION - D 160
LO0172 PID - LO0172
LO0172 STATE/COUNTY- UT/SUMMIT
LO0172 COUNTRY - US
LO0172 USGS QUAD - MIRROR LAKE (1972)
LO0172
LO0172 *CURRENT SURVEY CONTROL
LO0172 ______________________________________________________________________
LO0172* NAD 83(1986) POSITION- 40 41 14. (N) 110 54 18. (W) SCALED
LO0172* NAVD 88 ORTHO HEIGHT - 3267.338 (meters) 10719.59 (feet) ADJUSTED
LO0172 GEOID HEIGHT - -12.899 (meters) GEOID12B
LO0172 DYNAMIC HEIGHT - 3263.797 (meters) 10707.97 (feet) COMP
LO0172 MODELED GRAVITY - 979,418.8 (mgal) NAVD 88
LO0172
LO0172 VERT ORDER - SECOND CLASS 0
LO0172
LO0172.The horizontal coordinates were scaled from a topographic map and have
LO0172.an estimated accuracy of +/- 6 seconds.
LO0172.
LO0172.The orthometric height was determined by differential leveling and
LO0172.adjusted by the NATIONAL GEODETIC SURVEY
LO0172.in June 1991.
LO0172
LO0172.Significant digits in the geoid height do not necessarily reflect accuracy.
LO0172.GEOID12B height accuracy estimate available here.
LO0172
LO0172.The dynamic height is computed by dividing the NAVD 88
LO0172.geopotential number by the normal gravity value computed on the
LO0172.Geodetic Reference System of 1980 (GRS 80) ellipsoid at 45
LO0172.degrees latitude (g = 980.6199 gals.).
LO0172
LO0172.The modeled gravity was interpolated from observed gravity values.
LO0172
LO0172; North East Units Estimated Accuracy
LO0172;SPC UT N - 1,039,470. 550,300. MT (+/- 180 meters Scaled)
LO0172
LO0172_U.S. NATIONAL GRID SPATIAL ADDRESS: 12TWL080040(NAD 83)
LO0172
LO0172 SUPERSEDED SURVEY CONTROL
LO0172
LO0172 NGVD 29 (??/??/92) 3265.798 (m) 10714.54 (f) ADJ UNCH 2 0
LO0172
LO0172.Superseded values are not recommended for survey control.
LO0172
LO0172.NGS no longer adjusts projects to the NAD 27 or NGVD 29 datums.
LO0172.See file dsdata.pdf to determine how the superseded data were derived.
LO0172
LO0172_MARKER: DB = BENCH MARK DISK
LO0172_SETTING: 66 = SET IN ROCK OUTCROP
LO0172_STAMPING: D 160 1962
LO0172_STABILITY: A = MOST RELIABLE AND EXPECTED TO HOLD
LO0172+STABILITY: POSITION/ELEVATION WELL
LO0172
LO0172 HISTORY - Date Condition Report By
LO0172 HISTORY - 1962 MONUMENTED CGS
LO0172
LO0172 STATION DESCRIPTION
LO0172
LO0172'DESCRIBED BY COAST AND GEODETIC SURVEY 1962
LO0172'30.1 MI NE FROM KAMAS.
LO0172'30.1 MILES NORTHEAST ALONG STATE HIGHWAY 150 FROM THE JUNCTION OF U.S.
LO0172'HIGHWAY 189 ALTERNATE AT KAMAS, 34.7 FEET SOUTH OF THE SOUTHWEST POST
LO0172'SUPPORTING BALD MTN, ELEVATION 10,678 FT. SIGN, 53 FEET SOUTHWEST OF
LO0172'THE CENTER LINE OF THE HIGHWAY, 82 FEET WEST OF THE CENTER OF THE
LO0172'JUNCTION OF BALD MOUNTAIN TRAIL ROAD, IN THE TOP OF A MASSIVE OUTCROP,
LO0172'ABOUT 1 FOOT LOWER THAN THE HIGHWAY, AND 1.0 FOOT ABOVE THE GROUND.
Posted : April 16, 2017 8:42 pm
[USER=228]@Loyal[/USER]
That country fascinates me. Any photos looking about the horizon please?
Interested in your reason for the observations.
Is it a job or an interest?
Either way it'd be both for me.
You've got some fascinating country.
(I've watched Longmire for a while, gives a good look at your neck of the woods, but probably filmed all over the place?)
I'd miss the smell of our eucalyptus forests though.
Posted : April 16, 2017 8:54 pm
Richard, post: 423826, member: 833 wrote: [USER=228]@Loyal[/USER]
Mark might post a few pictures that "pan around' the site.
The good ones will be in a couple of months when I can get up to D160 in the Uintas.
Posted : April 16, 2017 9:04 pm
What do y
Posted : April 16, 2017 9:06 pm
Gene Kooper
(@gene-kooper)
I seem to recall that spot, but it has been more than a few years.
I don't remember you bringing lawn chairs though!
P.S. Nice sandstone obelisk. As I recall there are some chisel marks on at least two faces (I wasn't able to find an NGS data sheet for it).
Posted : April 16, 2017 9:16 pm
Gene Kooper, post: 423830, member: 9850 wrote: I seem to recall that spot, but it has been more than a few years.
It's got a LOT of scribing on all four sides. As I recall, it was cut and marked in SLC, and brought to the site in a wagon.
Here's the Data Sheet
PROGRAM = datasheet95, VERSION = 8.12.1
LO0707 ***********************************************************************
LO0707 DESIGNATION - WYOMING SW COR
LO0707 PID - LO0707
LO0707 STATE/COUNTY- UT/SUMMIT
LO0707 COUNTRY - US
LO0707 USGS QUAD - RED HOLE (1972)
LO0707
LO0707 *CURRENT SURVEY CONTROL
LO0707 ______________________________________________________________________
LO0707* NAD 83(1994) POSITION- 40 59 52.36386(N) 111 02 48.54114(W) ADJUSTED
LO0707* NAVD 88[/URL] ORTHO HEIGHT - 2181.14 (+/-2cm) 7156.0 (feet) VERTCON
LO0707 GEOID HEIGHT - -14.742 (meters) GEOID12B
LO0707 LAPLACE CORR - 7.47 (seconds) DEFLEC12B
LO0707 HORZ ORDER - FIRST
LO0707 VERT ORDER - THIRD ? (See Below)
LO0707
LO0707.The horizontal coordinates were established by classical geodetic methods
LO0707.and adjusted by the National Geodetic Survey in November 1997.
LO0707.
LO0707.The NAVD 88 height was computed by applying the VERTCON shift value to
LO0707.the NGVD 29 height (displayed under SUPERSEDED SURVEY CONTROL.)
LO0707
LO0707.Significant digits in the geoid height do not necessarily reflect accuracy.
LO0707.GEOID12B height accuracy estimate available here.
LO0707
LO0707.The vertical order pertains to the NGVD 29 superseded value.
LO0707
LO0707.Photographs are available for this station.
LO0707
LO0707.The Laplace correction was computed from DEFLEC12B derived deflections.
LO0707
LO0707. The following values were computed from the NAD 83(1994) position.
LO0707
LO0707; North East Units Scale Factor Converg.
LO0707;SPC UT N - 1,073,896.556 538,128.410 MT 0.99996653 +0 17 55.7
LO0707;SPC UT N - 3,523,275.62 1,765,509.63 sFT 0.99996653 +0 17 55.7
LO0707;SPC WY W - 155,732.669 718,939.052 MT 1.00001834 -0 37 55.6
LO0707;SPC WY W - 510,932.93 2,358,719.21 sFT 1.00001834 -0 37 55.6
LO0707;UTM 12 - 4,538,522.649 496,062.494 MT 0.99960019 -0 01 50.6
LO0707
LO0707! - Elev Factor x Scale Factor = Combined Factor
LO0707!SPC UT N - 0.99966029 x 0.99996653 = 0.99962684
LO0707!SPC WY W - 0.99966029 x 1.00001834 = 0.99967863
LO0707!UTM 12 - 0.99966029 x 0.99960019 = 0.99926062
LO0707
LO0707: Primary Azimuth Mark Grid Az
LO0707:SPC UT N - WYOMING SW COR AZ MK 002 54 04.0
LO0707:SPC WY W - WYOMING SW COR AZ MK 003 49 55.3
LO0707:UTM 12 - WYOMING SW COR AZ MK 003 13 50.3
LO0707
LO0707_U.S. NATIONAL GRID SPATIAL ADDRESS: 12TVL9606238522(NAD 83)
LO0707
LO0707|---------------------------------------------------------------------|
LO0707| PID Reference Object Distance Geod. Az |
LO0707| dddmmss.s |
LO0707| MR0340 WYOMING SW COR AZ MK 0031159.7 |
LO0707| MR0679 AIR BEACON 54 APPROX. 4.5 KM 0445108.9 |
LO0707| CM6804 WYOMING SW COR RM 1 11.331 METERS 20600 |
LO0707| LO0708 AIR BCN S END PORCUPINE RIDGE APPROX. 6.6 KM 2525110.3 |
LO0707| CM6805 WYOMING SW COR RM 2 10.965 METERS 29252 |
LO0707
LO0707 SUPERSEDED SURVEY CONTROL
LO0707
LO0707 NAD 83(1993)- 40 59 52.36399(N) 111 02 48.54097(W) AD( ) 1
LO0707 NAD 83(1986)- 40 59 52.34973(N) 111 02 48.53038(W) AD( ) 1
LO0707 NAD 27 - 40 59 52.53595(N) 111 02 45.88035(W) AD( ) 1
LO0707 NGVD 29 2179.74 (m) 7151.4 (f) LEVELING 3
LO0707
LO0707.Superseded values are not recommended for survey control.
LO0707
LO0707.NGS no longer adjusts projects to the NAD 27 or NGVD 29 datums.
LO0707.See file dsdata.pdf to determine how the superseded data were derived.
LO0707
LO0707_MARKER: DD = SURVEY DISK
LO0707_SETTING: 0 = UNSPECIFIED SETTING
LO0707_SATELLITE: THE SITE LOCATION WAS REPORTED AS SUITABLE FOR
LO0707+SATELLITE: SATELLITE OBSERVATIONS - April 24, 2012
LO0707
LO0707 HISTORY - Date Condition Report By
LO0707 HISTORY - 1938 MONUMENTED USGS
LO0707 HISTORY - 20060617 GOOD INDIV
LO0707 HISTORY - 20111001 GOOD GEOCAC
LO0707 HISTORY - 20120424 GOOD GEOCAC
LO0707
LO0707 STATION DESCRIPTION
LO0707
LO0707'DESCRIBED BY US GEOLOGICAL SURVEY 1938 (FGJ)
LO0707'STATION IS THE SOUTHWEST CORNER MONUMENT OF WYOMING. IT IS
LO0707'A LARGE SANDSTONE POST ABOUT 14 INCHES SQUARE AT THE BOTTOM
LO0707'AND ABOUT 12 INCHES SQUARE AT THE TOP AND ABOUT 4 FEET HIGH
LO0707'SET VERTICALLY IN THE GROUND. IN THE TOP OF THE POST IS SET A
LO0707'STANDARD U.S.G.S. BRASS BENCH MARK MARKED ELEVATION ABOVE SEA
LO0707'LEVEL 7150 FT. DATUM EVEN SLACK.
LO0707'
LO0707'REFERENCE AND AZIMUTH MARKS ARE STANDARD BRONZE DISKS SET
LO0707'IN CONCRETE AS DESCRIBED.
LO0707'
LO0707'REACHED FROM THE POST OFFICE IN COALVILLE BY GOING NORTH TWO
LO0707'BLOCKS TO A GRAVEL STREET RIGHT, THIS IS THE FIRST STREET SOUTH
LO0707'OF WARDS SERVICE. HERE TURN RIGHT, EAST, AND FOLLOW GRADED
LO0707'DIRT AND GRAVEL MAIN TRAVELED ROAD, UP CHALK CREEK FOR 18.1
LO0707'MILES TO THE PINE CLIFF DANCE HALL, STORE, AND CABINS ON THE
LO0707'RIGHT. THENCE CONTINUE NORTHERLY ON MAIN TRAVELED ROAD FOR
LO0707'5.6 MILES TO A FORK JUST AFTER CROSSING A SMALL WASH. THENCE
LO0707'RIGHT, NORTHEAST, ON TRAIL ROAD 0.25 MILE TO A SIDE ROAD
LO0707'RIGHT. THENCE RIGHT, SOUTH, FOR 0.05 MILE TO A BRIDGE. PASS
LO0707'OVER BRIDGE AND FOLLOW MAIN TRAIL ROAD 0.05 MILE TO A FORK.
LO0707'THENCE LEFT, SOUTHEAST, ON MAIN TRAVELED ROAD FOR 0.3 MILE
LO0707'TO A FORK. THENCE LEFT FORK, SOUTHERLY, MAIN TRAVELED
LO0707'ROAD, FOR 0.4 MILE TO A POINT JUST AFTER CROSSING A SMALL
LO0707'DRAW. THENCE LEAVE TRAIL AND TURN RIGHT, SOUTHERLY,
LO0707'CROSS COUNTRY COVERED WITH SAGE BRUSH TO A FOUR-FOOT RED
LO0707'SANDSTONE POST, MARKING STATION.
LO0707'
LO0707'AZIMUTH MARK IS SET IN THE INTERSECTION OF MAIN ROAD UP CHALK
LO0707'CREEK AND THE TRAIL ROAD LEADING OFF TO THE NORTHEAST. IT
LO0707'IS ABOUT 20 FEET EAST OF THE MAIN ROAD AND ABOUT 20 FEET NORTH
LO0707'OF THE TRAIL ROAD. TWO STANDARD REFERENCE MARKS WERE SET AND
LO0707'STAMPED (WYO. SW COR. USGS. 1938)
LO0707
LO0707 STATION RECOVERY (2006)
LO0707
LO0707'RECOVERY NOTE BY INDIVIDUAL CONTRIBUTORS 2006 (HDM)
LO0707'DID NOT RECOVER RM'S. IF RM'S ARE NOT DESTROYED THEY ARE UNDER
LO0707'PAVEMENT OF ROAD ON SOUTH AND WEST SIDES OF STATION MARK.
LO0707
LO0707 STATION RECOVERY (2011)
LO0707
LO0707'RECOVERY NOTE BY GEOCACHING 2011 (MEL)
LO0707'NO REFERENCE OBJECTS SEEN.
LO0707
LO0707 STATION RECOVERY (2012)
LO0707
LO0707'RECOVERY NOTE BY GEOCACHING 2012 (BRB)
LO0707'A NEW DESCRIPTION IS REQUIRED AS THE ROUTING OF THE ROADS HAS CHANGED
LO0707'ALONG WITH OTHER DETAILS OF THE 1938 NARRATIVE.
LO0707'THE REFERENCE MARKS AND AZIMUTH MARK WERE NOT SEARCHED.
I first used it to help constrain a trilateration network that covered about 50 sq. miles back about 1980ish.
Posted : April 16, 2017 9:31 pm
We put up signs, "SURVEY MARKER, DO NOT DISTURB."
So if anyone talks I say, "Shhhh don't disturb the monument."
Posted : April 16, 2017 9:37 pm
Gene Kooper
(@gene-kooper)
Loyal,
I looked for all the data sheets in Uinta County, WY and only found the azimuth mark. I see the data sheet states that the SW corner of Wyoming is in Summit County, Utah.
Note to self: Don't assume that the NGS State/County search will find all stations on the State and/or County line!
Posted : April 16, 2017 9:50 pm
Gene Kooper
(@gene-kooper)
Well, I searched on Uinta County, Wyoming and only found the azimuth mark. The data sheet shows the SW Corner of Wyoming as being in Summit County, Utah.
Note to self: Don't assume that searching NGS data sheets by State/County will pull up all stations on the State and/or County line.
Posted : April 16, 2017 10:01 pm
Page 1 / 3
