Anybody out there quit using TDS Foresight and are interested in selling their hardware lock? I have Foresight DXM, but am looking for a surveyor slanted drafting package. Thanks in advance. You can email me at dhunter@dslextreme.com
I have it and I think it sucks for drafting. You're probably better off with Carlson Survey. The one distinct advantage of Foresight is that it runs on a Terramodel engine, which makes it ideal for creating DTMs. In addition to being able to create DTMs, if you're using a TDS based data collector it creates a space saving file with an extension .dtm, which is much smaller than an XML or other type. The least squares module totally sucks.
Ralph
Ralph
I have a TDS Ranger w/Survey Pro data collector. I am trying out a 30 day trial of Carlson right now. Thanks for your advice.
Dennis Hunter, PLS PE
hi sirs does anyone have the instalation files for foresight dxm 3.4.1??
PINOST, post: 429698, member: 8430 wrote: hi sirs does anyone have the instalation files for foresight dxm 3.4.1??
I have them at home. Unfortunately I I'm a few thousand miles away right now.
If you don't find them by Monday update this thread, I'll be watching it.
bobwesterman, post: 430049, member: 7106 wrote: I have them at home. Unfortunately I I'm a few thousand miles away right now.
https://www.dropbox.com/s/hap6nwvqge62c82/ForeSightDXM_3.4.1.zip?dl=0
The Link above should get you a zip file with:
ForeSightDXM_3.4.1.exe The Installation files.
ForeSightDXM_RefManual_May2011.pdf The reference Manual.
ForeSightDXM_UG_May2011.pdf The user Manual.
I seem to recall needing a new Sentinel System driver for either Windows 7 or windows 10
Here is a link for that:
https://www.dropbox.com/s/ww94ha5agu946sx/Sentinel-System-Driver-Installer-7.5.9_Windows.zip?dl=0
These links should work for a while, but If you need them get them while you can, you never know when I might move or even delete these file since we seldom use DXM anymore. We've changed to ACCESS.
bobwesterman, post: 430301, member: 7106 wrote: https://www.dropbox.com/s/hap6nwvqge62c82/ForeSightDXM_3.4.1.zip?dl=0
ForeSightDXM_UG_May2011.pdf The user Manual.I seem to recall needing a new Sentinel System driver for either Windows 7 or windows 10
SIR ...MANY MANY MANY MANY MANY MANY THANKS FOR THIS HELP !!!!!!!!!!!!!
Does anyone have Terramodel locks for sale? Do you have any Foresight or Foresight DXM locks you'd be willing to part with? Thanks.
