I do not get all the data to come in when I try to import a tds file into Carlson 2008 standalone. What am I missing? I have process raw files before and it has been a while so I cannot remember the exact steps....
thanks for the help
I use Topcon Link to process the Tds File.
then import as ascii.
It used to be a free program from Topcon, but do not know about now.
Hope this helps.
Randy
What exactly isn't coming in?
I process TDS/Survey Pro .raw files, as well as Carlson .rw5 files, all the time - with no problems with either.
JB,NM1402-g,DT05-18-2014,TM06:27:22
MO,AD0,UN2,SF1.0,EC0,EO0.0,AU0
--File exported from Survey Pro
above is all I see
I cannot figure out what I am doing wrong
Are you sure that you had the raw file collection turned on in the instrument? Does the cr5 file have all the points?
Dtp
You may have to change the extension to *.rw5 from *.raw. I have to do it on every file I d/l.
