TBC for Surveyors
measuredirt
(@measuredirt)
How many people out there are using TBC on a regular basis? What are some of the features that benefit in the heavy civil world? Thanks for your thoughts.
Posted : April 14, 2015 2:12 pm
vern
 vern
(@vern)
BENEFITS? Cue the crickets.
For Civil applications there are better choices.
Posted : April 14, 2015 2:32 pm
Dan Steely
(@dan-steely)
You did see where he said Heavy Civil, right?
If using trimble machine control then this is obviously your only choice. I find the surface building functions very reliable and accurate for corridor grading. Building templates and alignment are cake.
Posted : April 14, 2015 4:28 pm
lee-d
(@lee-d)
I use it daily to process RTK, static, and Pipelines data, it works fine for that. It will also do a passable job on field-to-finish if you take the time to set it up and learn it, although I don't presently use it for that. The least squares adjustment is a little weak in some areas but is good enough for the rare occasions that I need it - I've taken to processing static networks in OPUS Projects here lately, but I still run it through TBC as a check.
If you run a lot of Trimble GPS and/or data collectors it's handy to have.
Posted : April 15, 2015 6:24 am
