T-Mobile & Network RTK Latency
The Pseudo Ranger
(@the-pseudo-ranger)
I've been somewhat frustrated with my RTK experience for a long time. I use a Galaxy phone as a mobile hotspot through T-Mobile, a Hiper Pro, and a Nomad with SurvCE.
What I see is that my latency is usually bounces between 0 - 2 seconds when the RTK is working properly. But way too often, in areas with good cell coverage, and no obstructions, it will kick into autonomous, and often stay there for a minute or three, before going back to fixed ...
If this were an occasional problem, I can deal with it, but this repeats itself all days long, with probably more down time than up time.
I often look at the latency when this happens, and it normally climbs as high as 10-15 seconds, then resets to zero, then climbs back up to 10-15 seconds, and repeats that pattern while stuck in autonomous. Eventually it will settle back in at 0-2 and go back to fixed, but sometimes it times out and triggers an automatic reconnect attempt through SurvCE.
By my way of thinking, this almost has to be a problem with the carrier being slow at streaming the data. I know people who use Verizon on the same RTK network and latency is never a problem. Am I overlooking another possible source of latency here, or do I need to switch carriers? It doesn't seem to be specific to the area I'm working in, or satellite conditions, or phone bars. It's a problem I get all the time anywhere I'm working.
Posted : July 25, 2014 1:42 pm
stephen-ward
(@stephen-ward)
It might be the phone itself.
I had an S3 until I recently switched to a Note3. USCellular is my carrier, but I don't think that is where the issue is. With either of my phones if I have wifi enabled and it finds a weak open wifi network it will try to swap from 3g/4g to the open wifi signal. Usually this leads to a flaky connection as it tries to swap back and forth.
Another possibility is that other apps on the phone are periodically using data and messing with the connection
Posted : July 25, 2014 1:54 pm
lee-d
(@lee-d)
Regardless of the carrier, I'd get away from the phone and switch to a WiFi. We use MiFi Liberates on AT&T and rarely have problems.
A lot of people in New Orleans were using T-Mobile after Katrina because they were about the only option for a while. I don't know about where you're at but down here Verizon and AT&T are much better options.
Posted : July 25, 2014 2:00 pm
Sat Al
(@sat-al)
I've ran into this, and it's always been the carrier. If it's that repeatable, a quick check would be to use the Wifi connection at your house (or McDonalds parking lot) instead of T-Mobile and see how it behaves.
In my experience, Mifi devices tend to behave better because they are built for data streaming.
Posted : July 25, 2014 4:25 pm
The Pseudo Ranger
Thanks,
Good advice here. My wife has an I-phone on T-mobile with a hotspot that I can barrow and try it out, that could at least eliminate my phone/apps as the problem.
Also, that's a good idea about jumping on a McDonalds WiFi network to see if the data flow is any better. I might even be able to barrow a Verizon MiFi from friend and try it out for a weekend.
I do like having the phone/hotspot all-in-one, though ...
Posted : July 25, 2014 5:32 pm
Sat Al
(@sat-al)
I understand. I love the Wifi hotspot feature on my phone. More than I thought I would. It's super convenient.
I've never used it for all-day RTK streaming. Just for a couple of hours at a time here and there. Given my phone
> Thanks,
Posted : July 26, 2014 10:57 am
