Super Tall Geodesy
20 Users
scott-zelenak
(@scott-zelenak)
In the early evening of Friday, June 14th, 2013 seven men met in the warm darkness of a busy city sidewalk and discussed the work that was scheduled for the night. All trades had left the building and all elevator operations had ceased except for the one exterior hoist. That hoist was at their disposal.
The evening temperature was projected to be constant and the wind less than 5 miles per hour.
In the previous days the three crews with their total stations had visited a calibration base line to determine constants and scalars, and the instruments collimated for horizontal, vertical, and level on the construction site. The three levels were pegged and collimation errors determined.?ÿ Targets, plummets, plate levels and tripods adjusted and the three optical plummets adjusted looking down or up from a bridge between the 15th floor of two buildings on Broadway.?ÿ
Equipment, procedure and a realistic estimation of error propagation are more important than any adjustment technique. But even a rigorous theory cannot completely describe reality.
A city like New York is never quiet at night and the sidewalks are constantly occupied as people move about. It's not rush hour by any means, but cute couples, cops and silly drunks keep it entertaining. The pretty giggly gaggles of girls tend to impede the progress the most, for some inexplicable reason. Most, at night, are polite, cheerful, and empathetic as they enjoy their night and as we obviously labor on some mysterious but nevertheless significant project.?ÿ
Semi-serious men are doing strange things with extravagant equipment in the dark.
We share the sidewalk happily, for what passes by and how we interact will provide numerous hours of entertainment later.
But now, specific instructions have been issued.
A minimum of eight sets were to be successfully obtained in the next six hours of astronomical twilight. Seemingly an easy objective, it required that instruments, targets and levels be reset after each set to randomize centering, leveling, and height measure errors.?ÿ The levels were bucked in to the instruments and targets between each set, with the height mark carefully split between the inclined crosshairs of the level, so heights could be determined with micrometers.?ÿ Eccentric targets and instruments carefully arranged so lines of sight crossed, providing identical atmospheric conditions for the significantly inclined sight lines.
At the northernmost station an unattended delivery truck obstructed a line of sight, so Agency police were contacted and an Agency tow truck from the Tunnel arrived and moved the offending vehicle off the line after a half hour delay.
Meanwhile, operations had begun to the south.
Strict instructions were issued as to how a successful set was obtained. After four sets the mean was calculated, as well as the standard deviation and a list of Chauvenet constants provided so a rejection criteria could be calculated in the field by each crew chief.?ÿ After six, eight, ten and twelve sets the criteria were recomputed and outliers detected and new sets observed if necessary.?ÿ I'm sure I will take some criticism for not using a more rigorous approach, however, this method requires nothing fancier than a scientific calculator in the field and produces results compatible with more stringent test methods.
Two men attended each backsight, instrument, level and eccentric target. And each required resetting, releveling and remeasuring of HI and HT with the level between each set.?ÿ A considerable amount of work for a mere eight sets.
As the sun broke the horizon on June 15th and the high eastern face of the building began to rise in temperature, the nights work concluded.
Now, the calculations would commence and geodesy, gravity and geometry would dictate the results.
The magnitude of each correction to be considered is small. However, there is a tendency for each to accumulate and systematic error, considerably more harmful than random error, must be accounted for and corrected.
Our trig pillar and test bay.
The traverse to the lobby, the simultaneous reciprocal zenith roof traverse and the optical, laser and mechanical plumbing to connect through the shaft cells.
The reduction of all this data requires some manipulation.?ÿ First we weed outliers out of the raw.
After crunching through the raw, we gather some known data and run some preliminary computations and check?ÿthe angular misclose.
Next we compute our radii on the ellipse in the azimuths required.
Now we can also apply corrections to the distances for the constants and scalars computed on the calibration base line, and correct for the atmospheric ppms (which here, for instance, were incorrect in that they didn't average between the ground and the roof stations) and second velocity and chord.
Now we can reduce our traverse, making corrections along the line for curvature of the plumbline, deflection of the vertical, skew normal, and the geodesic.
And here we have our ellipsoidal data, and we do another azimuth closure, check our trig heights, and our coordinate differences.
We can now compute constants and variables for our projection.
Now, after using the?ÿplumbing to connect the roof and lobby traverse we can use a concept borrowed from monitoring to determine if our plumbing closes and the roof point and lobby point are identical.?ÿ The monitoring concept uses the coordinates of each point, its associated error ellipse and some computation to determine if the points are identical.
And..."we missed it by that much."
[Insert appropriate expletive]!
So what have we done wrong?
Well, we haven't gone far enough.
There are many things to consider in a plumbing operation of 500 meters.
Most notable, are the corrections for convergence of the plumbs and deflection of the vertical.
Deflection of the vertical, which is often thought of as a difference of position on the face of the earth between astronomic and geodetic coordinates, is also the angle between the ellipsoid normal at a point and the direction of gravity at the same point.?ÿ And it's components (xi and eta) along with our plumbed dimension?ÿprovide enough to compute the azimuth of this deflection and its linear effects.
Yes, we adjusted our lobby and roof traverses for the deflection of the vertical, and so too must we adjust the plumbs which obviously?ÿare not normal to the ellipsoid but?ÿcollinear with the direction of?ÿgravity.?ÿ So we take our deflection components (given in geographic terms and converted into grid values) and compute the total deflections at the bottom and use them to correct our roof coordinates.
Now, how'd we do?
Ok, life is good again.?ÿ
Now for some sidebars.
I hope NGS addresses this in 2020.?ÿ
And, Nate I believe, asked if anyone ever used a 500 foot tape.?ÿ I can say, "No."
But how many people use a 500 meter mine shaft calibrated invar tape?
That's 1,640 feet on one reel.?ÿ We used to call it the "quarter miler".
Enjoy.
Posted : August 15, 2018 9:44 am
daniel-ralph
(@daniel-ralph)
Bravo!?ÿ
Posted : August 15, 2018 10:01 am
At the same time you should have been taking GNSS observations at the 4 corners at the top of said structure for comparison. I said 4 corners because rather obviously the spire will block various signals at all 4 observation points.
That tape?ÿwould be 1640.420 International Feet, not 1640.417 Us Survey Feet, since the US handles elevations universally in I. Ft.?ÿ
BTW, do you account for the different feet in the construction monitoring?
Do you tape down and up, meaning the two?
Addendum, using XYZ coordinates calculations can be made irrelevant of geoid or ellipsoid. Finding the plumb at height requires one to have to include the additional velocity/acceleration at altitude.
Posted : August 15, 2018 10:24 am
stlsurveyor
(@stlsurveyor)
These are examples of projects I will never have the opportunity to work on - and wouldn't even know where to begin! Thank you so much for sharing.
Your experiences on this project would make a great text/memoir! Another Chapter in the book "Beerleg"
Fantastic work - and I have seen the end results in person!
N10,000, E7,000, Z100.00
PLS - IL, MO, AR, KS, MN, KY
Posted : August 15, 2018 10:31 am
Posted by: Paul in PA
Who told you that?
LO0172?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ *CURRENT SURVEY CONTROL
LO0172?ÿ ______________________________________________________________________
LO0172* NAD 83(1986) POSITION- 40 41 14.?ÿ?ÿ?ÿ?ÿ (N) 110 54 18.?ÿ?ÿ?ÿ?ÿ (W)?ÿ?ÿ SCALED?ÿ?ÿ?ÿ
LO0172* NAVD 88 ORTHO HEIGHT -?ÿ 3267.338 (meters)?ÿ?ÿ?ÿ 10719.59?ÿ (feet) ADJUSTED?ÿ
LO0172?ÿ GEOID HEIGHT?ÿ?ÿ?ÿ -?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ -12.899 (meters)?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ GEOID12B
LO0172?ÿ DYNAMIC HEIGHT?ÿ -?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ 3263.797 (meters)?ÿ?ÿ?ÿ 10707.97?ÿ (feet) COMP
LO0172?ÿ MODELED GRAVITY -?ÿ?ÿ?ÿ 979,418.8?ÿ?ÿ (mgal)?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ?ÿ NAVD 88
Posted : August 15, 2018 10:36 am
The US converts meters to international feet except where the state has documented use of the US survey foot and that is for position. I am unaware of any state having documented an official foot for elevations.
Posted : August 15, 2018 10:55 am
jamesf1
(@jamesf1)
Scott,
I'm not sure why life was bad prior to your work, or exactly why you were performing it, but I did find your documentation interesting. I took a look and found that I had those two lines in my copy of NOS NGS 5 highlighted. I wonder if ESSA Technical report C&GS 36 qualifies as a "text on higher geodesy"? Probably not...
Posted : August 15, 2018 11:17 am
Larry Best
(@larry-best)
Yeah, I do that all the time staking out houses.
Thank you Scott Z. Wonderful post!
Posted : August 15, 2018 11:19 am
While various states use one kind of foot or the other for horizontal, I expect most just use the NGS data sheets to define elevations, which as Loyal pointed out are in US Survey feet.
From?ÿ https://www.ngs.noaa.gov/faq.shtml
The only other instance where NGS publishes linear values in feet is for elevations, i.e., orthometric heights. All computations are still done in meters, but for publication purposes we convert meters to feet. That conversion is done using the U.S. Survey Foot conversion factor. We publish elevations in meters to the nearest millimeter (3 decimal places) and in feet to hundredths of a foot (2 decimal places). For elevations above 5,000 feet (1,524 meters), the conversion factor will change the foot value by one in the second place
Posted : August 15, 2018 11:25 am
squowse
(@squowse)
Was the purpose to check the optical plumb? Can it not just be checked by reversing it?
That is pretty amazing though. 500m vertically.
Posted : August 15, 2018 11:56 am
FrozenNorth
(@frozennorth)
Cite please.
That which can be asserted without evidence can be dismissed without evidence.
Posted : August 15, 2018 1:12 pm
tim-v-pls
(@tim-v-pls)
Dude. That's friggin' awesome!
Posted : August 15, 2018 1:24 pm
Dear North,
"I am unaware of any state having documented an official foot for elevations."
Please cite one that has.
Posted : August 15, 2018 2:15 pm
Warren Smith
(@warren-smith)
California's Public Resources Code section 8893 provides that "COH88 values shall be expressed in meters and decimals of a meter or in feet and decimals of a foot.?ÿ When COH88 values are expressed in feet, the "US Survey Foot," (one foot equals 1200/3937 meters) shall be used as the standard foot."
COH88 refers to California Orthometric Heights of 1988.
So it would conform with NGS datasheets after all.
Posted : August 15, 2018 2:26 pm
andy-j
(@andy-j)
Absolutely amazing, and well written! I can't imagine how difficult it is to keep track of all that AND work around the city hustle.?ÿ?ÿ
Posted : August 15, 2018 3:02 pm
And here in PA it is International Feet
MA0655 ______________________________________________________________________
MA0655* NAD 83(1986) POSITION- 41 58 48.5 (N) 078 37 15.4 (W) HD_HELD2
MA0655* NAVD 88 ORTHO HEIGHT - 433.395 (meters) 1421.90 (feet) ADJUSTED
Posted : August 15, 2018 4:21 pm
That is not a high enough point to see the difference in the two kinds of feet.?ÿ As noted in the quote above, it takes at least 5000 ft to show the difference in the 2nd decimal.
433.395 meters is 1421.8968 US survey feet, which rounds to the value given.
433.395 meters is 1421.8996 International feet, which also rounds to the value given.
What makes you think PA would convert ortho height to international feet??ÿ This is not evidence thereof.
Posted : August 15, 2018 4:54 pm
What does that prove?
433.395 x iFT = 1421.8996 ft. = 1421.90
433.395 x sFT = 1421.8968 ft. = 1421.90
As stated in Bill's post, you need to get a LOT higher than Pennsylvania before it makes a real difference, and even then it's not much.
Loyal?ÿ
edit...oops butter fingers
stlsurveyor
(@stlsurveyor)
Another great post high-jacked.
This is the same BS that drove and still drives members away.?ÿ
Such a waste of energy.
Thank you for all the time assembling the OP.?ÿ
Posted : August 15, 2018 5:03 pm
Let's look at Montana, an International foot state according to a list I found.?ÿ Unfortunately the really high ones I looked were all VERTCON, so not given to sufficient precision for a comparison.
 QX0623* NAD 83(1986) POSITION- 45 00 05.4    (N) 110 00 06.1    (W)   HD_HELD2
 QX0623* NAVD 88 ORTHO HEIGHT -  2249.923 (meters)     7381.62  (feet) ADJUSTED
2249.923 meters = 7381.6224 US Survey ft, rounds to 7381.62
2249.923 meters = 7381.6371 International ft, rounds to 7381.64
So this is an example of an International ft state where NGS still gives US feet, as noted in the quote above.
Posted : August 15, 2018 5:36 pm
