Spectrum Survey - Conversion to RINEX
2 Users
j-penry
(@j-penry)
When converting a Sokkia PDC file to RINEX in Spectrum Survey V2.11 the default options are shown below with only the "Disable C2 output" box checked. What are the best options to use? I am using GSR2700 ISX antennas doing 2+ hour static sessions.
Posted : August 29, 2012 8:45 am
gto234
(@gto234)
From the manual:
In the Options section:
• Select the Convert only aligned epochs check box to export data that
is aligned to epochs to the RINEX format.
• Select Export GPS only to export only GPS data (GLONASS data will
not be included).
• Select Disable C2 output to disable L2C observations. This will allow
the RINEX file to work in OPUS-RS.
Posted : October 3, 2012 4:46 am
