sokkia grs2700isx
2 Users
(@foggyidea)
I'm having an issue with my static collection.
Sunday, 3/17 I used the unit in static mode to collect data on a monument we set at the Boston Common.
I turned on the unit, let it run it's course until it was ready then I reset the instrument to factory settings (hold theon button down until it tells you it's resetting) then turned it off and on again at 10:50AM.
At 3:10PM I swtiched it off, the battery was still more than half strength so I figured all is well.
Whe I submitted to OPUS for inclusion in their data base I received a note back that 4 hours is required for a submission. I thought I had almot 4.5 hours....
When I look at the file that is returned from OPUS it's a pretty ggod solution but only shows at start at 14:51:00 and Stop at 18:10:00, only 3 hours and 20 minutes...
Where's my extra hour?
Another concern that I have is that Spectrum or Sokkia planning seem to download differing files on occasion. In other words, I may end up with a 2140KB PDC file, or a 840KB PDC file....
Any clues??
Thanks,
Don
PS I have actually downliading a number of time and it appears that the 3:20 time is consistent, ot at least I've received that answer three times.
Posted : March 21, 2013 7:57 am
(@artie-kay)
Don, I've had similar problems with the base off and on but not identical to yours. My temporary solution has been to configure the rover as base and the base as rover.
I don't follow why you do the factory reset, I usually load the static collection powerup configuration before leaving the office.
Maybe the memory card was full? I suppose you could try reloading the receiver's firmware + delete all the static files on the card and reformat the card.
Posted : March 21, 2013 11:21 am
